I have a Leitner Headset both at the office and home. I use Jabber only when home. I would like to be able to auto answer a call when one comes in. I would also like to hear the ringer on my PC. The settings with Jabber are set up that way but the PC does not ring. Only the headset rings provided it is on. Not like when at work with my cisco phone where it will ring if the headset is off and I can turn it on from there. Is it possible/compatible to do this? My version is 12.9.5.55511 Build 305511. I do not have an Auto Answer option on my settings.
