11-26-2011 02:05 PM - edited 03-16-2019 08:15 AM
I have used the command line command "file delete license" to delete a bac license file tac issued me. After deleting the file I restarted the Cisco CallManager service.
The counts are still showing up though when I go to System / Licensing / License Unit Report
I have even got in and deleted all the license files, restarted the Publisher and tried uploading the correct files again. The system tells me the file has already been uploaded.
System version: 8.5.1.10000-26
Any one have any idea how to reset the license counts to default?
If I can reset to the defaults then I can upload the correct files again.
11-26-2011 03:11 PM
Hi.
Try to restart Cisco License Manager service.
Cisco Unified Serviceability -->> Tools --->> Control Center - Network Services
Hope this helps
Carlo
11-26-2011 03:32 PM
Yes I tried restarting Cisco License Manager service on the Publisher and both subscribers. I even went so far as to reboot all 3 servers.
Still showing the incorrect numbers :-(
I'm looking through the bug tool kit now to see if I am hitting a bug.
Thanks for your responce Carlo!
11-26-2011 04:04 PM
Hi.
Please post the output of the following commnads.
file list license *
run sql select * from licenseinfo
Let me know
Carlo
11-26-2011 04:47 PM
admin:file list license *
dir count = 0, file count = 0
admin:
admin:run sql select * from licenseinfo
pkid fklicenseserver tklicensefeature licenseunits overdraftunits macaddress version origmacid licfileid licfileversion isdemo licenselineid upgradefromwindows isvalid
dd12353c-ae2d-482a-b6eb-5e300abe1789 f8fe34ec-d537-4c39-b87b-edc36d09d6b7 1 1 0 4e7a5409ea15 5.0 4e7a5409ea15 20111118114424536 2.0 f 1 f t
6460a79d-017a-4f86-955d-dd6f76e808b0 f8fe34ec-d537-4c39-b87b-edc36d09d6b7 2 51333 0 4e7a5409ea15 5.0 4e7a5409ea15 20111125154708298 2.0 f 1 f t
e24b925e-06c5-406c-a1c8-c0e8fa044f76 f8fe34ec-d537-4c39-b87b-edc36d09d6b7 3 1 0 4e7a5409ea15 8.0 4e7a5409ea15 20111116025756415 2.0 f 1 f t
50df7f1e-e65d-48ed-b278-d82b694fcf60 f8fe34ec-d537-4c39-b87b-edc36d09d6b7 3 1 0 4e7a5409ea15 8.0 4e7a5409ea15 20111118114424536 2.0 f 2 f t
5d587fb1-5209-4dac-b768-4615ac7bee25 f8fe34ec-d537-4c39-b87b-edc36d09d6b7 1 1 0 4e7a5409ea15 5.0 4e7a5409ea15 20111118115115392 2.0 f 1 f t
10c5ed1a-cd85-41ba-8363-0fcafe8035ff f8fe34ec-d537-4c39-b87b-edc36d09d6b7 3 1 0 4e7a5409ea15 8.0 4e7a5409ea15 20111118115115392 2.0 f 2 f t
cd2264e5-93f1-4c94-a0d8-8123a0b72b50 f8fe34ec-d537-4c39-b87b-edc36d09d6b7 1 1 0 4e7a5409ea15 5.0 4e7a5409ea15 20111118120338569 2.0 f 1 f t
77f5da58-7bfd-468e-843e-13bbb583f97e f8fe34ec-d537-4c39-b87b-edc36d09d6b7 3 1 0 4e7a5409ea15 8.0 4e7a5409ea15 20111118120338569 2.0 f 2 f t
5c7cd78d-2050-496c-b4c2-115243e7fabe f8fe34ec-d537-4c39-b87b-edc36d09d6b7 1 1 0 4e7a5409ea15 5.0 4e7a5409ea15 20111118120446818 2.0 f 1 f t
eeb16cba-3288-4f32-a443-b3aef7567569 f8fe34ec-d537-4c39-b87b-edc36d09d6b7 3 1 0 4e7a5409ea15 8.0 4e7a5409ea15 20111118120446818 2.0 f 2 f t
32d6aa18-f851-467b-b372-60b5dd9f832f f8fe34ec-d537-4c39-b87b-edc36d09d6b7 1 1 0 4e7a5409ea15 5.0 4e7a5409ea15 20111118120654326 2.0 f 1 f t
9f61f673-5f17-4fe7-96a7-fddd2d31d311 f8fe34ec-d537-4c39-b87b-edc36d09d6b7 3 1 0 4e7a5409ea15 8.0 4e7a5409ea15 20111118120654326 2.0 f 2 f t
2d397bfc-4422-4335-b84c-fa033a7234b5 f8fe34ec-d537-4c39-b87b-edc36d09d6b7 1 1 0 4e7a5409ea15 5.0 4e7a5409ea15 20111118120753899 2.0 f 1 f t
c284
c284
11-26-2011 05:20 PM
d99491ad-4036-4c57-a6db-8630be65f3b4 f8fe34ec-d537-4c39-b87b-edc36d09d6b7 1 51333 0 4e7a5409ea15 5.0 4e7a5409ea15 20111125154403413 2.0 f 1 f t
THis is the bad license file -- 20111125154403413
11-26-2011 11:26 PM
Hi.
I think you should open a TAC to obtain root access to delete wrong licenseinfo entries from the CUCM DB.
Hope this helps.
Carlo
11-27-2011 06:47 AM
Yea, I did that last night shortly after I posted to the community. The engineer accepted the ticket then took a P2 case and could not assist me. I went ahead and requeued just now. When I try to run the delete command I get denied.
admin:run sql delete from licenseinfo where licfileid = '20111125154403413'
No DELETE permission for licenseinfo.
I'll update this thread with the resolution when i get one. Thanks again Carlo for your input!
Del
11-27-2011 07:05 AM
Hi Del,
Looks like it may be this bug;
Description
Symptoms:
The DB entries are not removed after removing the license file via cli command
file delete license
Conditions:
This problem happens when there is only a license file uploaded in the server
and user removes the license file
Workaround:
user will need to remove the corresponding DB entries in licenseinfo table.
For performing this, TAC will need to be contacted.
Note CUP will also document this issue and declare CUP doesn't support valid
license removal through the CLI command. The only time that user needs to
remove the license file is a publisher rehost is performed and the original
license file becomes invalid. users will need to upload a new license file,
use this cli command to remove the invalid license file, then restart license
manager.
Further Problem Description:
Details
7.1(3.10000.11)
More
Less
Status:
Open
Last Modified:
Oct 28,2011
More
Less
8.6(2.10000.30), 8.6(2.10000.27), 8.5(1.13900.4)
More
Less
Product:
Cisco Unified Communications Manager (CallManager)
Platform:
Dependent
Severity:
3 - moderate
It seems that your TAC case is your best bet here.
Cheers!
Rob
11-27-2011 07:33 AM
Thanks Rob, Not sure how I missed this one last night when I was searching through the bug tool kit myself. I'll blame it on the left over Turkey dinner sleepy eyes!
Del
11-27-2011 08:01 AM
Hey Del,
You are most welcome my friend!
Even without the leftover Turkey the Bug Toolkit can make your eyes
glaze over ....hahahahaha
Cheers!
Rob
11-27-2011 01:21 PM
Final Resoltion by TAC:
**** TAC had to get root access and delete the license entrys in the database. ****
Thank you to Carlo for your suggestion to lookup the license files and compare that with what the database listed.
file list license *
Thank you Rob for finding the bug ID CSCtc59039
08-02-2013 11:10 AM
hello,
We have CUCM 8.0.3 and we are running into the same situation. But, when we contact TAC, the engineer told us that as soon as he deletes all the entries from licenseinfo, the whole phone system will be down (all devices become 'unregistered'). And, there will be an major service interruption. He couldn't tell us how long the interruption will be 30 minutes, 1hr, ....
Could somebody provide me some information according to your experience? if there will be an service interruption, how long will it be?
Thanks in advance!
Aug 5, 2013
The license issue has been fix by TAC engineer, and the service interruption was less than 3 minutes (we have ~5000 phone devices).
