11-21-2012 06:03 AM - edited 03-16-2019 02:19 PM
Hello i wanna change my CUCM subnet mask, running on VMWARE, i know that i will need to rehost the license for new license mac.
•Certificate Information (Organization, Unit, Location, State, Country)
My question is when i change the subnet mask, what will happen with my DLUs for the old License MAC?
The phones will lost register?
Solved! Go to Solution.
11-21-2012 06:11 AM
You get a 30 day grace period to get the new license, only after that time, you'll have problems.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
11-21-2012 06:15 AM
Hey Leonardo,
You'd be good to go for 30 days
Cisco Unified Communications Manager on the Cisco UCS C210 Rack-Mount Server uses a different licensing model than Cisco Unified Communications Manager on an MCS server. The MAC address of the NIC card is no longer used to associate the license to the server.
Instead, the license gets associated to a license MAC, which is a 12 digit HEX value created by hashing the following parameters that you configure on the server:
The ways to obtain the license MAC are as follows:
•Before installation, use the Answer File Generator (http://www.cisco.com/web/cuc_afg/index.html). When you generate the answer file, you also get the license MAC.
Note If you use this method, ensure that you enter the identical parameter values in the Answer File Generator and the Cisco Unified Communications Manager installation program, or the license will be invalid.
•After installation, navigate to Show > System in Cisco Unified Communications Manager Administration.
•After installation, use the CLI command show status.
Obtaining New Licenses
The process to redeem a Product Activation Key (PAK) for licenses at www.cisco.com/go/license is changed for a license MAC. When redeeming a PAK for a license MAC at this URL, you get prompted to select the type of license that you want to obtain:
•A physical MAC address — this is used when Cisco Unified Communications Manager will be installed on an MCS server.
•A license MAC address — this is used when Cisco Unified Communications Manager will be installed on Cisco Unified Communications Manager on the Cisco UCS C210 Rack-Mount Server.
After you make this selection, the generation and installation of the license file follows the same process.
Obtaining Rehosted Licenses When You Change License MAC Parameters
When you change any of the parameters that create the license MAC, the license that you obtained with it becomes invalid. You must request a rehosting of the license to obtain a valid license. The old license continues to work for a 30-day grace period.
To rehost your licenses, you must open a case with the licensing team. Contact the licensing team at licensing@cisco.com.
During the grace period, you can change the settings back to the licensed values to make your original license valid again. If you need more than 30 days of grace period, change your settings back to the licensed values, then change them back to the new values that you want to use. You will get another 30- day grace period.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/8_0_1/delta/vmware.html#wp1058262
Cheers!
Rob
"And if I should fall behind
Wait for me" - Springsteen
11-21-2012 06:11 AM
java
11-21-2012 06:15 AM
Hey Leonardo,
Cheers!
Rob
11-21-2012 06:16 AM
Hey Java,
You've trumped me once again my friend +5 for your continuing
stellar support here @ CSC!
Cheers!
Huff
11-21-2012 08:12 AM
Hello Java and Rob,
Thanks again for the help!
Leonardo Santana
11-30-2012 02:13 AM
Also, be careful not to raise the mask above a /23. The ARP table size has been hard set to 1024 addresses within the OS. Anything higher than that and you'll run into issues when the table fills.
Please remember to rate helpful responses and identify helpful or correct answers.
11-30-2012 04:11 AM
Hello Jonathan
Thanks for this info, do you what type of issues can we face with a mask above /23?
11-30-2012 06:28 AM
In theory it would force CUCM to perform an ARP for every packet it wanted to send to an IP that wasn't in it's table. I cannot imagine a legitimate design where you would need a voice server VLAN larger than /24, let alone /23.
Note The recommendation to limit the number of devices in a single Unified Communications VLAN to approximately 512 is not solely due to the need to control the amount of VLAN broadcast traffic. For Linux-based Unified CM server platforms, the ARP cache has a hard limit of 1024 devices. Installing Unified CM in a VLAN with an IP subnet containing more than 1024 devices can cause the Unified CM server ARP cache to fill up quickly, which can seriously affect communications between the Unified CM server and other Unified Communications endpoints. Even though the ARP cache size on Windows-based Unified CM server platforms expands dynamically, Cisco strongly recommends a limit of 512 devices in any VLAN regardless of the operating system used by the Unified CM server platform.
