License requirement for 6901 to register with cucm 8.6
frank3333
Hi All,
Licensing
Phone licensing is dependent on the call-control platform and its policies. For Cisco Unified Communications Manager Versions 7.1(3) and 7.1(4), the Cisco Unified IP Phone 6901 requires two device license units (DLU); for Cisco Unified Communications Manager Version 7.1(5) and later, the User Connect License (UCL) fee for basic phones will be applied to the Cisco Unified IP Phone 6901. There are no special license-plus-phone bundles for tier 2 distributors.
can we use DLU for 6901 -
                   How many DLUs required for 6901?
 or is it essential to but UCL for register 6901 on cucm 8.6
                    can you share the UCL license code for 6901?
2 Accepted Solutions
Hi Frank.
As per license unit calculator, 6901 does not consume any license on 8.6.
You can look at license unit calculator under System --> Licensing
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Frank.
CUCM 8.6 version is still DLU licensing model and , while 6901 consumes 0 DLU, you can purchase it without additional license.
Carlo
Hi Frank.
Carlo
Yes i checked on that. does it mean we just need to order only phone units.and doesn't required any type of license for 6901 to register with 8.6?  i need to clarify on this before order.
Thanks Carlo another help from you.
Thanks.
Hi Frank.
Carlo
Tested with one 6901 and it is registered without DLUs.
Thanks.
But DLUs  going to end of sale since jan 2015.
