Licensing cme-srst Issue on Cisco 2911
Mohammad Usman
I have a new 2911 VSEC/K9 bundled router which is running IOS c2900-universalk9-mz.SPA.151-4.M4.bin. I have configured CME as Cisco recommend. I enable EULA I found this below error.
CME licensing (cme-srst) feature enabled with no license installed
Also these error message on console when I reboot the router.
Jan  1 02:56:00.543: %LICENSE-1-VALIDITY_ENDED: Feature cme-srst 1.0  has expire
UDI=CISCO2911/K9:FCZ162ning old versionStamps
CNF-FILES: Clock is not valid or synchronized,
                retaining old versionStamps
How may I resolve this issue? please do let me know,
Usman
8 Replies 8
Ayodeji Okanlawon
Mohammed,
Can you send us a "show license" on the gateway and a show license detail
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Thanks for you reply, please see the mentioned detail:
Router#sh license
Index 1 Feature: ipbasek9
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Medium
Index 2 Feature: securityk9
Index 3 Feature: uck9
Index 4 Feature: datak9
        Period left: Not Activated
        Period Used: 0  minute  0  second
        License Type: EvalRightToUse
        License State: Not in Use, EULA not accepted
        License Priority: None
Index 5 Feature: gatekeeper
Index 6 Feature: SSL_VPN
        License Count: 0/0  (In-use/Violation)
Index 7 Feature: ios-ips-update
Index 8 Feature: SNASw
Index 9 Feature: hseck9
Index 10 Feature: cme-srst
        Period left: 8  weeks 4  days
        License State: Active, Not in Use, EULA accepted
        License Priority: Low
Index 11 Feature: WAAS_Express
Index 12 Feature: UCVideo
Router# sh license detail
Index: 1        Feature: SNASw                             Version: 1.0
            Evaluation total period: 8  weeks 4  days
            Evaluation period left: 8  weeks 4  days
            Period used: 0  minute  0  second
        Store Index: 6
        Store Name: Built-In License Storage
Index: 2        Feature: SSL_VPN                           Version: 1.0
        Store Index: 4
Index: 3        Feature: UCVideo                           Version: 1.0
        Store Index: 9
Index: 4        Feature: WAAS_Express                      Version: 1.0
        Store Index: 8
Index: 5        Feature: cme-srst                          Version: 1.0
        Store Index: 7
Index: 6        Feature: datak9                            Version: 1.0
        Store Index: 2
Index: 7        Feature: gatekeeper                        Version: 1.0
        Store Index: 3
Index: 8        Feature: ios-ips-update                    Version: 1.0
        Store Index: 5
Index: 9        Feature: ipbasek9                          Version: 1.0
        Store Index: 0
        Store Name: Primary License Storage
Index: 10       Feature: securityk9                        Version: 1.0
        Store Index: 2
Index: 11       Feature: securityk9                        Version: 1.0
        License State: Inactive
        Store Index: 0
Index: 12       Feature: uck9                              Version: 1.0
        Store Index: 1
Index: 13       Feature: uck9                              Version: 1.0
        Store Index: 1
Also see the "show version" commond's output
Device#   PID                   SN
*0        CISCO2911/K9          FCZ1620700N
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9    Permanent      securityk9
uc            uck9          Permanent      uck9
data          None          None           None
The CME-SRST license is simply on a per honour basis, when you order the voice bundle you get 25 SRST licenses included, and you purchase additional quantities or units to fulfil your SRST requirements. There is no specific license to install, you simply accept the EULA and the CME-Srst feature will be valid for 12 years and no longer on EvalRightToUse basis.
Allan
Actually when I create the cnf-files in telephony service, I got an error message which that is below
I have already set the clock time:
CME# clock set 13:32:21 1 Oct  2012
CME# write mem
wehen I reboot the router:
I am getting the above again from console and time has changed to default. and the same thing I got
Configure NTP servers for accurate clock.
Thanks for your reply, actually I have also configured the valid NTP server but the same issue presist.
If you need further detail regarding this I will provide you.
Usman
Check "show ntp assoc".
I took the smartnet for thw said issue, it is an battery failure happening during router boot up, which makes the time to Feb 6 2036.
Error message:
“Feb  6 16:35:09.000: %MAINBOARD-3-RTC_BATTERY_
FAILURE: Real Time Clock (RTC) oscillator problem detected, possibly caused by RTC battery failure”
reply from Cisco TAC Engineer:
"I suspect the time change after the reboot as a hardware issue"
Thanks CISCO TAC team.
Usman
