Licensing for VM
angel-moon
Level 3
Level 3
Hello everyone,
If I am trying to register a license for a UC virtual install do I register the physical MAC or the virtual?
Thanks in advance!  All replies rated.
anchoudh
Level 9
Level 9
Its the Licens MAC you need to use it for getting the license.
Please use the below link,
http://www.cisco.com/web/cuc_afg/index.html
Anand
Rob Huffman
Hi Angel,
I just wanted to add this reference to the great tips from Anand (+5 )
With VMware the license is created in a new/different manner that's why you are
seeing this new "license mac" reference;
Customer Impact from New Licensing Procedures
Cisco  Unified Communications Manager on VMware on Cisco UCS B-Series Blade  Servers uses a different licensing model than Cisco Unified  Communications Manager on an MCS server. The MAC address of the NIC card  is no longer used to associate the license to the server.
Instead,  the license gets associated to a license MAC, which is a 12 digit HEX  value created by hashing the following parameters that you configure on  the server:
Time zone
NTP server 1 (or "none")
NIC speed (or "auto")
Hostname
IP Address (or "dhcp")
IP Mask (or "dhcp")
Gateway Address (or "dhcp")
Primary DNS (or "dhcp")
SMTP server (or "none")
Certificate Information (Organization, Unit, Location, State, Country)
This hash of these fields is called the LICENSE MAC
Note : Once there is a change in any of the parameters that creates the License MAC, it will
give you 30 day grace period to generate a new license file for the CM based on new license
MAC.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/8_0_2/install/cmins802.html#wp584709
Cheers!
Rob
"Always movin' ahead and never lookin' back" - Springsteen
Rob and Anand,
Thanks!
