Limit available ring tones per phone
Wes Schochet
Level 3
Level 3
I have users with 7925's and CUCM 6.1.  The supervisors are asking that I limit the ring tone chices.  Is there a way to limit this without limiting all phones?
Wes
Jaime Valencia
The phones get the ringlist from the TFTP server they have configured.
You'd need to set a separate TFTP for those phones to get their configurations and also to look at for ring tones.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
