10-29-2018 01:32 AM - edited 03-17-2019 01:39 PM
Hi Guys,
I have a hunt pilot that has several hunt list members. I want to limit the concurrent call received by the members up to 3 concurrent call, so the 4th caller will be notified that the line is busy (voice recording). I did some digging, someone said that this could be accomplished by using queue. So I changed the queue value and did some verification. Somehow the hunt list members still received call from the 4th and even 5th caller. I am sure something is wrong with my configuration. Below is my current configuration. Any idea which part that I should change?
Thank you.
03-12-2019 09:39 AM
Did you ever sort this out? I have the same request from a customer and can't seem to get it to work. In my case it is further complicated by a call handler transferring the calls to the hunt pilot.
I will open a TAC case.
03-21-2019 11:38 PM
Hi wsteahr01,
Unfortunately not. I had to changed the scheme.
Do you mind to share the result from TAC? Would be helpful for others :)
03-22-2019 05:16 PM
Let us know how you go as according to the configguide this should work as intended.
03-23-2019 11:31 PM
