06-15-2011 11:34 PM - edited 03-16-2019 05:28 AM
Is there a way to limit / restrict Simultaneous Incoming Calls on E1/T1 links, using the incoming called-number along with the max-conn commands doesn't help, also it works great with incoming H.323 calls.
Any hints,
06-15-2011 11:54 PM
From the top of my head,
You can loop the call as a h323 call then send it out to the IP Leg
Will need a couple of translation patterns.!
Let me check
/divin
06-16-2011 12:03 AM
Thanks divin for your instant reply, but I really couldn't get your point, would you please be more specific?
P.S: I have no problem with Incoming or Outgoing calls thru E1, all i need to do is to set limit on Incoming E1 calls to allow more voice channels for outgoing calls.
06-16-2011 12:45 AM
What I intend to do is,
PSTN calls 3000 hits inbound POTS dial-peer, then use a translation rule
change the called number to 113000 then
this matches a voip dial-peer pointing to this router itself
Now the call is a h323 call You can do the max-conn .
use transalation-profiles to change the 113000 to 3000 and route the call to final destination.
If you hit the max-conn then the call will just disconnect
Or just ask the provider to send only X number of calls inbound!
/divin
