03-18-2011 08:53 AM - edited 03-16-2019 04:01 AM
Hi all,
I don't know if it is possible to implement a feature with the CUCM that can restrict users to call more than a limited time per month or per call, ... anything that can limit calls (ex: user A can make calls with a duration of 120 min per month or something like that). Please let me know in case someone knows any third party application that can acheive something like that ...
Solved! Go to Solution.
03-18-2011 09:12 AM
I am not really sure , i didn't saw it before on CUCM but it's availble on third party and i did it once before through a company called nevotek , they have this program with the billing software.
Amer
03-18-2011 09:12 AM
Amer
03-22-2011 01:40 AM
Hi Amer,
Thanks, I guess thats what i need. You are talking bout the sigma 5 i think. Is it easy to configure and does it require a special type of hardware and database? I would appreciate if you can share with me your info ...
03-22-2011 01:49 AM
Last time i bought the sigma five was like 3 years ago , it's better to check with the company (nevotek) for the mimum specs , they will give it to you when you request a proposal.
Amer
09-19-2011 12:10 PM
We are Cisco Solution Developer Partner, and we have Call Management, billing & Quote systems that integrate with CUCM
Let me know if you are interested, and I can send you an evaluation copy & application data sheet
My email : mohamed.abdallah@connectps.com
Mohamed
09-20-2011 12:45 AM
Hi Mohamed,
I am interested to check your product for future implementations. Kindly send me an evaluation copy with the necessary documentation (user guide, …) in order to try it and check the differences with some other products
Best regards,
Wissam
