07-16-2012 04:43 AM - edited 03-16-2019 12:12 PM
This is probably a routine task for many of you, but my telephony knowledge is very thin, even though I`m the only one in the company administering it :-/ So I appologize in advance.
CCME 8 with around 150 IP phones (6921s and 6941s). I`d like to create and limit outgoing calls to a group of ~15 phones. All outgoing calls are blocked, except 2 mobile phones. They still should be able to communicate internally. Communication with the rest of the network is optional - would be neat to saw off that branch as well.
This group is group of retail shop phones, and we dont want shop workers to dial anything else beside their managers (2 mobile phones) and other stores.
Please point me in right direction Thank you!
Solved! Go to Solution.
07-17-2012 08:09 AM
Glad you are figuring it out..Thats the point of learning. Yes you cant leave all other dial-peers without cor applied to them, cor wont take effect as you have seen.
Yes you can add multiple destination to a dial-peer
eh
destination-pattern 0676280..
will match 100 numbers 0676280.........067628099
So you can use the . as a wildmask for other numbers
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
07-16-2012 04:57 AM
As simple as it sounds, its not that easy to implement on CCME. You need to use cor lists to create the restrictions.
Here is an excellent link on how to configure COR (class of restrictions)
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
07-16-2012 06:27 AM
Thank you very much! I will read through it, and ask in this same topic if I have any further questions
07-16-2012 06:29 AM
Milos,
You are most welcome and we will be glad to help you should you need further assistance
07-16-2012 12:38 PM
One question if I may. I never configured dial-peers myself (I see them as voice static routes..), so I already have them in place. What Im not sure about is should I create new ones for these two specific mobile numbers, and "stick" COR to them?
Thank you,
Milos
07-17-2012 01:24 AM
You will need to implement it on the dial-peers. The dial-peer you shouldnt apply it to is the one for the mobile phones. If you send your router config (sh run) I can help you with the config.
07-17-2012 02:27 AM
You are a life savior! Here a portion of the config with dial-peers:
dial-peer voice 11 pots
description === izlazni 112 poziv ka Telekomu ===
destination-pattern 112
port 0/0/0:15
forward-digits 3
dial-peer voice 12 pots
description === izlazni pozivi ka Telekomu - razne sluzbe 1 ===
destination-pattern 12[2-6,8]
port 0/0/0:15
forward-digits 3
dial-peer voice 13 pots
description === izlazni pozivi ka Telekomu - razne sluzbe 2 ===
destination-pattern 1....
port 0/0/0:15
forward-digits 4
dial-peer voice 14 pots
description === izlazni pozivi ka Telekomu - taksi sluzbe ===
destination-pattern 19...
port 0/0/0:15
forward-digits 5
dial-peer voice 20 pots
description === izlazni pozivi ka Telekomu - gradski poziv ===
destination-pattern [2-8].....
port 0/0/0:15
forward-digits 6
dial-peer voice 21 pots
description === izlazni pozivi ka Telekomu - medjugradski poziv ===
destination-pattern 0[2-5].......
port 0/0/0:15
forward-digits 9
dial-peer voice 22 pots
description === izlazni pozivi ka Telekomu - mobilne mreze ===
destination-pattern 06[3,7-9].......
port 0/0/0:15
forward-digits 10
dial-peer voice 25 pots
description === izlazni pozivi ka Telekomu - medjunarodni poziv ===
destination-pattern 00T
port 0/0/0:15
prefix 00
dial-peer voice 3 voip
clid strip
dial-peer voice 30 voip
destination-pattern 9997..
session target ipv4:172.18.1.99
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 26 pots
description === izlazni pozivi ka Telekomu - all ===
destination-pattern .T
port 0/0/0:15
dial-peer voice 700 voip
destination-pattern 7...
dial-peer voice 8555 voip
destination-pattern 8555
session target ipv4:10.50.255.254
num-exp 600... 660...
gatekeeper
shutdown
telephony-service
max-ephones 365
max-dn 300
ip source-address 192.168.219.5 port 2000
caller-id block code *1234
timeouts interdigit 3
system message porto montenegro
load ata ATA030203SCCP051201A.zup
load 6921 SCCP69xx.8-5-3-0.loads
load 6941 SCCP69xx.8-5-3-0.loads
load 6961 SCCP69xx.8-5-3-0.loads
load 6901 SCCP6901.9-0-2-0.loads
load 6911 SCCP6911.9-0-2-0.loads
max-conferences 8 gain -6
moh flash:/music-on-hold.au
web admin system name admin secret 5 $1$fCZ/$POPmTbYIuUjCwxMXZVRd3.
dn-webedit
transfer-system full-consult
create cnf-files version-stamp 7960 Jun 23 2011 11:51:28
So I guess I`ll have to create new dial-peers for these two mobiles? One dial-peer per one mobile number? Lets assume number is 067628086.
I can not thank you enough
07-17-2012 03:38 AM
Milos,
Ok here we go...
Requirement
1. 15 phones are giving full access
2. All phones can call 2 mobile numbers
3. All other outside calls from phones are blocked
1. We create dial-peer cor custom to define how we will apply cor to dial-peers
Dial−peer cor custom
name Full_Access
name Allowed_Mobile
2. We create the list of restrictions that apply to the dial-peers
dial-peer cor list FullAccess
member Full_Access
member Allowed_Mobile
dial-peer cor list Restricted
memeber Allowed_Mobile
3. Apply the corlist to the relevant outbound dial-peer
e.g
corlist outgoing FullAccess
NB: Apply this to all the other dial-peers you want to restcrict access to.
4. Apply the ff: to the two mobile numbers you want to give access to: I suggest you create a different dial-peer to match those two numbers
e,g dial-peer voice 40 pots
destination-pattern 063788888 (chnage this to the mobile number you want to give access to)
corlist outgoing Restricted
5. Finally assign cor list to the ephoens/ephone-dns you want to give access to and want to restrict.
e.g
ephone1-----------------------This will be one of the 15 phones you want to give full access to
corlist incoming FullAccess
ephone 2--------------------------This will be the other phones.
corlist incoming Restricted
I like people by the name Milos. My boss 's name is Milos and he is a good man
07-17-2012 04:45 AM
Im off to try it out! Requirements are a bit different, but I think I got the logic. Group of 15 is going to be limited only to those two mobiles; everyone else will have full priviledges.
Milos thanks!
07-17-2012 05:25 AM
Ok, so I took a test phone, created a test dn 21, and tried it out. I still can call whoever I want from this test phone. Here`s what I did:
Created just one cor list:
ISR3945(config)#dial-peer cor custom
ISR3945(config-dp-cor)#name Restricted
ISR3945(config-dp-cor)#dial-peer cor list Restricted
ISR3945(config-dp-corlist)#member Restricted
ISR3945(config-dp-corlist)#exit
Applied it to new dial-peer:
ISR3945(config)#dial-peer voice 40 pots
ISR3945(config-dial-peer)#destination-pattern 067628086
ISR3945(config-dial-peer)#corlist outgoing Restricted
Created a test dn:
ISR3945(config)#ephone-dn 21 dual
ISR3945(config-ephone-dn)#number 661021
ISR3945(config-ephone-dn)#name Milos
ISR3945(config-ephone-dn)#label Milos
ISR3945(config-ephone-dn)#desc Milos
ISR3945(config-ephone-dn)#cor incoming Restricted
ISR3945(config-ephone-dn)#exit
ISR3945(config)#ephone 30
ISR3945(config-ephone)#button 1:21
ISR3945(config-ephone)#restart
restarting C89C.1DB5.C4BA
I left everything else untouched. All other dial-peers are unchanged, and only Restricted cor is created. I can still call whatever I want from this device. What am I missing? The plan is to block everything except 067628086 number.
07-17-2012 05:52 AM
Milos,
I will be away fro a few hours, I will respond when I get back..Dont worry we will sort this out..
07-17-2012 06:48 AM
I think I troubleshooted myself
First of all, I did not configure dial-peer 40 completely, so I added these two lines:
ISR3945(config-dial-peer)#port 0/0/0:15
ISR3945(config-dial-peer)#forward-digits 10
Then, I created another cor called Allowed, and "sticked" it to all other existing dial-peers. So basically, all dial-peers have Allowed, and dial-peer 40 has Restricted cor. Just the dn-s I want blocked have Restricted, others are cor-free.
So I believe Im close to wrapping this thing up, but I have one final question: Can multiple phone numbers be listed as multiple destination patterns in the same dial-peer? Or I have to create new dial-peers for individual numbers, and keed adding Restricted cor to it?
07-17-2012 08:09 AM
eh
07-17-2012 08:24 AM
Im immensely grateful! Thanks again
07-17-2012 08:31 AM
Thanks for the nice rating and good Luck.
