Line group problem
hjacquemin
Beginner
Beginner
Hello everyone,
I'm actually trying ton configure a line group on CCM 4.2 and I'm hitting a bug (I supposed but Cisco Bug Tool failled each time).
I have selected Broadcase as Distribution Algorithm but all the phone, which have a call pick up group configured in the line don't ring...
When I removed the call pick up group from the line configuration all work fine.
Someone can help me?
Hervé Jacquemin
1 ACCEPTED SOLUTION
Nizar Abuseni
Hello Herve,
Yes you are right there is a bug regarding this in version 4.X.
Please check the bellow document hope it helps you:
https://supportforums.cisco.com/docs/DOC-2011
Best regards,
Nizar
2 REPLIES 2
Nizar Abuseni
Hello Herve,
Best regards,
Nizar
Thank you !!
