02-24-2017 12:10 AM - edited 03-17-2019 09:38 AM
Hi!
There's anyway to report the active users in a CUCM Line Group? How?
Thanks!
Solved! Go to Solution.
02-24-2017 12:18 AM
Hi David,
No real report but, below should help.
http://www.ucguerrilla.com/2014/03/using-sql-to-report-on-hunt-pilots-and.html
https://supportforums.cisco.com/discussion/11038681/how-show-logged-line-group-members-hunt-pilot-cucm-v713
(Rate if it helps)
JB
02-24-2017 12:18 AM
Hi David,
(Rate if it helps)
JB
03-07-2017 02:06 AM
Hi!
It works well! But... there's anyway to make the SQL query without using CLI?
I read about it but don't understand :(
03-07-2017 08:54 AM
If you're looking for a GUI option in CUCM for SQL queries, there is none, the option is CLI or some other interface like AXL.
03-07-2017 11:56 PM
I'm looking for a system that can get the data via SQL Query to use in other systems of the company (in this case, Access), via CLI is slow. I will investigate about AXL but if you can publish a guide... ;)
Thanks!
