03-20-2017 02:59 AM - edited 03-17-2019 09:51 AM
We are using CUCM cluster setup where CUCM version 10.5.2.12901-1 ...there are total 80 Line groups are created...
Business needs information about the "Line group members" is there any way to export this information
Solved! Go to Solution.
03-20-2017 04:57 AM
You can do what Abhay says or, you can also go to Call Routing -> Route Plan Report on right top you will get an option to get the information in CSV file.
(Rate if it helps)
JB
03-20-2017 03:09 AM
You can use BAT to export the information regarding the Line Group Members. Choose the option of Line Group to export when you use BAT to export configuration data from CUCM.
Find this below link helpful for CM 9
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/bat/9_1_1/CUCM_BK_C271A69D_00_cucm-bulk-administration-guide-91/CUCM_BK_C271A69D_00_cucm-bulk-administration-guide-91_chapter_0111110.html
Abhay
Kindly rate all helpful posts !!!
03-20-2017 04:57 AM
(Rate if it helps)
JB
03-20-2017 10:34 PM
Hello Jitendra,
This is the most easy way to filter out ..thanks
03-20-2017 11:48 PM
I have CUCM 11.5. When i view file in CSV , It only list the hunt pilot number but do not list the Line Group Members.
