373
svadmin
Beginner
List Extension on Voice Gateway ports
We have two 350 Voice gateway and each has 96 ports on it.  they have fax number extension assigned to them,  is there a way to see a list of all the VG ports and the extension assigned to them?  Rather than going to port by port and grab the description and extension ?
2 REPLIES 2
Nipun Singh Raghav
If the VG is registered as MGCP or SCCP on CUCM, you can run report/find on there to view the extensions etc.
Nipun Singh Raghav
"We cannot solve our problems with the same thinking we used when we created them"
Hi Nipun,
The VG is registgered via MGCP
I tried to run a report but nothing showed up, do you have the proper steps to generate this report?
Create
Recognize Your Peers
Content for Community-Ad
