Live CCM MOH audio source from FXO port on router
chadlincoln
Level 3
Level 3
I've got a customer who wants to set up a live audio feed. I've got an FXO card in a router that is set up and ready to go for the live input. I've got the adapter ready to send the signal. My network is set up for multicast. What do I need to do on the CM side to have the live audio feed be an option under the phones/dn's as well as have the music play everywhere.
5 Replies 5
Jaime Valencia
Integrating Cisco CallManager and Cisco SRST to Use Cisco SRST As a Multicast MOH Resource
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00802d1c31.html
java
if this helps, please rate
java
Ya, been there, done that. The phones are set to use the sample audio file. That is what I hear. Where do I make it so they hear the music coming out of the FXO port on the router? Which file is that?
MOH from a Live Feed: Example
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmemoh.html#wp1010807
java
java
That's for CME. I'm using CM6.
I am in the same boat as chad, I have followed the docs mentioned above. But I don't know how to change my audio source in CCM.
It remains to play the default stream. I need for the MOH to play the Local Source that is plugged in the FXO card of the Remote router.
