12-08-2016 05:21 PM - edited 03-17-2019 08:54 AM
Hi all!
the ISR 2801 support or not support LMR services?
I need to add a PDVM module and more ram to make it work?
Here said that is supported....?¿
http://www.cisco.com/c/en/us/support/routers/2801-integrated-services-router-isr/model.html
Best Regards
Solved! Go to Solution.
12-08-2016 10:21 PM
Hi Francisco,
As per the LMR over IP design guide it is not supported
http://www.cisco.com/c/en/us/td/docs/wireless/lmr/design/guide/lmrsrnd_1/lmrsvcm.html
Manish
12-08-2016 10:21 PM
Hi Francisco,
Manish
