1003
Highlighted
Beginner
Local directory lookup in CME 9.1 with 9971 SIP phones
Hi all,
someone has already successfully configured the "service dnis dir-lookup" command in CME 9.1 (latest IOS update) with 9971 SIP phones (latest firmware updates)?
The goal is to show the local directory name (with number) on incoming ISDN calls.
With SCCP phones (eg. 7911) work correctly.
Thanks.
Massimo
2 REPLIES 2
Enthusiast
did you ever solved the
did you ever solved the problem?
Beginner
Does Anyone has a solution to
Does Anyone has a solution to the mentioned problem ?
Content for Community-Ad
August's Community Spotlight Awards
