06-20-2011 10:21 AM - edited 03-16-2019 05:32 AM
Hello, I have just installed a CUCM cluster version 8.6, and I don't find out the spanish locale file to download from cisco.com. The latest version is 8.5, but when I try to install it I receive an error: "Major and minor version numbers obtained from the name do NOT match those of the current version."
If I change manually the name to 8.6 I receive another error verifying the md5 hash.
So, where can we download the locale files version 8.6?
Regards.
06-20-2011 10:35 AM
Usually there is some delay between the time a CUCM release is posted and the locales and other stuff gets posted.
I'd recommend you to check again at least every couple of days for the next couple of weeks.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
06-20-2011 10:47 AM
Hello, I have revised the version 8.5 and I have seen that it takes one month between the release of CUCM8.5 and the locale of this version, and the CUCM8.6 dates from 9 June...
Regards.
