2632
Highlighted
Localization On CCME
We using Cisco 2801 ISR router with UCME 8.6. We try to use Turkish locale on IP phones configuring this router but we can't success. I installed it under telephony-service using command below but it didn't work. The file copied in its directory.
IOS: c2801-ipvoicek9-mz.151-4.M4.bin or c2801-spservicesk9-mz.151-4.M4.bin
user-locale 1 U1 load CME-locale-tr_TR-Turkish-8.6.2.4.tar
network-locale 1 U1
How we can set the Turkish locale on every phone?
Kindly regards,
9 REPLIES 9
Highlighted
Re: Localization On CCME
hi adnan,
you should try to set under ephone X the type of the phone...
e.g.
ephone 1
type 6961
telephony-service
create cnf-files
ephone 1
reset
- - or try following - -
telephony-service
cnf-file location flash:
cnf-file perphone
ephone-template  1
network-locale 1
user-locale 1
ephone  1
ephone-template 1
type 6961
telephony-service
create cnf-files
ephone 1
reset
let me know and don't forget to rate my post!
Konrad.
Highlighted
Hi Konrad,
Thanks for your answer but I already try them. And yes all types of phones set under ephone.
Kindly regards,
Highlighted
hi Adnan,
could you share the sh run?
thx
Highlighted
And that is
version 15.1
hostname CCME
boot-start-marker
boot-end-marker
enable secret 5 $1$G0L8$soz885829vmHcU5Hwxcol.
enable password xxxx
no aaa new-model
clock timezone GMT 3 0
dot11 syslog
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
voice-card 0
archive
log config
  hidekeys
username xxxx privilege 15 secret 5 $1$NumO$Ju72.z/07t9Pm0Toby5/z.
interface FastEthernet0/0
ip address 192.168.2.10 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:/gui
ip route 0.0.0.0 0.0.0.0 192.168.2.99
tftp-server flash:/Phones/7914/S00105000300.sbn
tftp-server flash:/Phones/7971/apps70.8-4-1-23.sbn
tftp-server flash:/Phones/7971/cnu70.8-4-1-23.sbn
tftp-server flash:/Phones/7971/cvm70sccp.8-4-1-23.sbn
tftp-server flash:/Phones/7971/dsp70.8-4-1-23.sbn
tftp-server flash:/Phones/7971/jar70sccp.8-4-1-23.sbn
tftp-server flash:/Phones/7971/SCCP70.8-4-2S.loads
tftp-server flash:/Phones/7971/term70.default.loads
tftp-server flash:/Phones/7971/term71.default.loads
tftp-server flash:/Phones/7961/apps41.8-4-1-23.sbn
tftp-server flash:/Phones/7961/cnu41.8-4-1-23.sbn
tftp-server flash:/Phones/7961/cvm41sccp.8-4-1-23.sbn
tftp-server flash:/Phones/7961/dsp41.8-4-1-23.sbn
tftp-server flash:/Phones/7961/jar41sccp.8-4-1-23.sbn
tftp-server flash:/Phones/7961/SCCP41.8-4-2S.loads
tftp-server flash:/Phones/7961/term41.default.loads
tftp-server flash:/Phones/7961/term61.default.loads
tftp-server flash:/Phones/7911/apps11.8-4-1-23.sbn
tftp-server flash:/Phones/7911/cnu11.8-4-1-23.sbn
tftp-server flash:/Phones/7911/cvm11sccp.8-4-1-23.sbn
tftp-server flash:/Phones/7911/dsp11.8-4-1-23.sbn
tftp-server flash:/Phones/7911/jar11sccp.8-4-1-23.sbn
tftp-server flash:/Phones/7911/SCCP11.8-4-2S.loads
tftp-server flash:/Phones/7911/term06.default.loads
tftp-server flash:/Phones/7911/term11.default.loads
control-plane
voice-port 0/0/0
translation-profile incoming reject
cptone TR
timing hookflash-out 50
connection plar 1221
caller-id enable
voice-port 0/0/1
cptone TR
caller-id enable
voice-port 0/0/2
cptone TR
shutdown
caller-id enable
voice-port 0/0/3
cptone TR
shutdown
caller-id enable
mgcp profile default
dial-peer voice 201 pots
description Emergency
destination-pattern 9T
port 0/0/0
dial-peer voice 202 pots
port 0/0/2
dial-peer voice 100 pots
description PSTN_XXXXXXX
destination-pattern [0]..........
port 0/0/0
dial-peer voice 101 pots
destination-pattern [2-8]......
port 0/0/0
dial-peer voice 102 pots
port 0/0/1
dial-peer voice 103 pots
port 0/0/1
dial-peer voice 301 pots
destination-pattern 9................
port 0/0/1
dial-peer voice 302 pots
port 0/0/0
dial-peer voice 106 pots
port 0/0/2
dial-peer voice 107 pots
port 0/0/2
dial-peer voice 501 pots
destination-pattern 00.T
port 0/0/0
dial-peer voice 502 pots
port 0/0/1
sip-ua
telephony-service
max-ephones 30
max-dn 100
ip source-address 192.168.2.10 port 2000
system message CCME
cnf-file perphone
network-locale 1 U1
load 7914 S00105000300
time-format 24
date-format dd-mm-yy
max-conferences 4 gain -6
moh test10.wav
transfer-system full-consult dss
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template  1
softkeys idle  Redial Newcall Gpickup
ephone-template  2
network-locale 1
user-locale 1
ephone-dn  20
number 1220
label 1220
name 1220
translate called 1
translation-profile incoming test
ephone-dn  21  dual-line
number 1221
ephone-dn  22
number 1222
pickup-group 1
label 1222
name 1222
ephone-dn  23
number 1223
pickup-group 1
label 1223
name 1223
ephone-dn  24
number 1224
pickup-group 1
label 1224
name 1224
ephone-dn  25
number 1225
pickup-group 1
label 1225
name 1225
ephone-dn  26  dual-line
number 1226
pickup-group 1
label 1226
name 1226
ephone-dn  27
number 1227
pickup-group 1
label 1227
name 1227
ephone-dn  28
number 1228
pickup-group 1
label 1228
name 1228
ephone-dn  29  dual-line
number 1229
pickup-group 1
label 1229
name 1229
ephone-dn  30
number 1230
pickup-group 1
label 1230
name 1230
ephone-dn  31
number 1231
pickup-group 1
label 1231
name 1231
ephone-dn  32
number 1232
pickup-group 1
label 1232
name 1232
ephone-dn  33
number 1233
pickup-group 1
label 1233
name 1233
ephone-dn  34
number 1234
pickup-group 1
label 1234
name 1234
ephone-dn  35
number 1235
pickup-group 1
label 1235
name 1235
ephone-dn  36
number 1236
label 1236
name 1236
ephone-dn  37
number 1237
label 1237
name 1237
ephone-dn  38
number 1238
pickup-group 1
label 1238
name 1238
ephone-dn  40
number 1240
pickup-group 1
label 1240
name 1240
ephone-dn  41
number 1241
label 1241
name 1241
ephone-dn  42
number 1242
pickup-group 1
label 1242
name 1242
ephone-dn  43
number 1213
label 1213
name 1213
ephone-dn  52
number 1212
label 1212
name 1212
ephone-dn  53
number 1216
label 1216
name 1216
ephone  1
mac-address 001C.58F9.A0B3
ephone-template 1
type 7911
button  1:35
ephone  2
mac-address 001D.A2F3.C7FA
ephone-template 1
type 7970
button  1:52
ephone  3
mac-address 001D.A2B7.EBCA
ephone-template 1
type 7911
button  1:34
ephone  4
mac-address 001E.7AC4.36C8
ephone-template 1
type 7911
button  1:22
ephone  5
mac-address 001D.A2B7.838F
ephone-template 1
type 7911
button  1o26,29
ephone  6
mac-address 001D.A2B7.EC18
ephone-template 1
type 7911
button  1:31
ephone  7
mac-address 001D.A2B7.EFC0
ephone-template 1
type 7911
button  1:30
ephone  8
mac-address 04C5.A44D.1B65
ephone-template 2
type 7911
button  1:20
ephone  9
mac-address 001B.5452.16FB
type 7961 addon 1 7914 2 7914
button  1:21 2m32 3m25 4m27
button  5m26 6m31 7m35 8m23
button  9m34 10m24 11m41 12m33
button  13m28 14m30 15m42 16m22
button  17m36 18m37 19m38
ephone  10
mac-address 001D.A2B7.EB65
ephone-template 1
type 7911
button  1o26,29
ephone  11
mac-address 001D.A2F3.B95E
ephone-template 1
type 7911
button  1:25
ephone  12
mac-address 001D.A2B8.1F5B
ephone-template 1
type 7911
button  1:33
ephone  13
mac-address 04C5.A44D.20E4
ephone-template 1
type 7911
button  1:42
ephone  14
mac-address 001D.A2F3.C4E1
ephone-template 1
type 7911
button  1:38
ephone  15
mac-address 64AE.0C5F.8A27
ephone-template 1
type 7911
button  1:32
ephone  16
mac-address 001D.A2F3.C723
ephone-template 1
type 7911
button  1:36
ephone  17
mac-address 001D.A2B7.669B
ephone-template 1
type 7911
button  1:27
ephone  18
mac-address 001D.A2B7.EEFE
ephone-template 1
type 7911
button  1:24
ephone  19
mac-address 001C.58F9.A109
ephone-template 1
type 7911
button  1:37
ephone  20
mac-address 0008.3031.BBBF
ephone-template 1
type 7911
button  1:23
ephone  21
mac-address 001D.A2F3.C2AA
ephone-template 1
type 7911
button  1:53
ephone  22
mac-address 001D.A2F3.BA28
ephone-template 1
type 7911
button  1:28
ephone  23
mac-address 0008.3031.B598
ephone-template 1
type 7911
button  1:40
ephone  24
mac-address 001D.A2B7.F049
type 7911
button  1:43
ephone  25
mac-address 0008.3031.B5EC
ephone-template 1
type 7911
button  1:41
ephone  28
mac-address 001D.A2B7.F97F
type 7911
button  1:53
line con 0
line aux 0
line vty 0 4
password xxxxx
login local
transport input all
scheduler allocate 20000 1000
end
CCME#
Highlighted
hi adnan,
you have assigned to all ephones the ephone-template 1 (except the ephone 8)
you must configure al ephones with ephone-template 2...
please check your config...
ephone-template  1
ephone-template  2
network-locale 1
user-locale 1
Konrad
dont forget to rate my post... if it was helpful...
Highlighted
Hall of Fame Master
Automatic localization doesn't really work.
You need to use the traditional method, that is to exact files using archive command. Then configure tftp-server for the approapriate model.
You can use debug tftp event to check the phone requesting and getting local files.
Highlighted
hi,
if u enter the following command, it takes some time, because the files will be xtracted automatically.
so you don't have to archive them manually. or i'm wrong?
i tested it with CME 8.6 and 9.0 - but with 69XX Phones... so i don't know if it's working with 79XX...
Konrad.
Highlighted
Hi Konrad,
Did it work with 69XX phones. I mean after that configuration (user-locale 1 U1 load CME-locale-tr_TR-Turkish-8.6.2.4.tar), did 69XX phones work with Turkish Locale?
I' m using C2801 and Cisco 79XX phones. I'm already using user-locale command under telephony-service and tftp's debug outputs below while I  reset the 7911 IP phone. Any Idea?
CCME#
Apr 25 07:52:37.931: %IPPHONE-6-UNREGISTER_NORMAL: ephone-8:SEP04C5A44D1B65 IP:192.168.2.187 Socket:7 DeviceType:Phone has unregistered normally.
Apr 25 07:53:23.550: TFTP: Looking for CTLSEP04C5A44D1B65.tlv
Apr 25 07:53:23.670: TFTP: Looking for SEP04C5A44D1B65.cnf.xml
Apr 25 07:53:27.669: TFTP: Looking for SEP04C5A44D1B65.cnf.xml
Apr 25 07:53:31.669: TFTP: Looking for SEP04C5A44D1B65.cnf.xml
Apr 25 07:53:35.669: TFTP: Looking for SEP04C5A44D1B65.cnf.xml
Apr 25 07:53:45.503: %IPPHONE-6-REG_ALARM: 22: Name=SEP04C5A44D1B65 Load= SCCP11.8-5-2S Last=Reset-Reset
Apr 25 07:53:45.547: %IPPHONE-6-REGISTER: ephone-8:SEP04C5A44D1B65 IP:192.168.2.187 Socket:13 DeviceType:Phone has registered.
CCME#
Adnan.
Highlighted
hi Adnan,
i've tested it successful on an 2921 with Version 15.1(4)M3 (CME 8.6) and 2901 with 15.2(2)T1 (CME9.0) with 6945 and 6961 Phones. i've done it with languages DE and IT - not tested with TR!
What i've done was following:
1) create folder "its" if not present "mkdir flash:/its"
2) copy tftp: flash:/its/CME-locale-de_DE-German-8.8.2.4.tar
3) copy tftp: flash:/its/CME-locale-it_IT-Italian-8.8.2.4.tar
4)
telephony-service
cnf-file perphone
user-locale 1 DE load CME-locale-de_DE-German-8.8.2.4.tar     ! when you enter this cmd it takes some time to extract the files -> it does the system automatically
user-locale 2 IT load CME-locale-it_IT-Italian-8.8.2.4.tar
network-locale 1 DE
network-locale 2 IT
ephone-template  1  ! german template
network-locale 2
user-locale 1
ephone-template  2  ! italian template
network-locale 2
user-locale 2
ephone  1
ephone-template 1
type 6945   !! important that the phone takes the new lang files
!!! IMPORTANT
telephony-service
create cnf-files
reset the phones...
Konrad
