04-24-2012 12:28 PM - edited 03-16-2019 10:48 AM
We using Cisco 2801 ISR router with UCME 8.6. We try to use Turkish locale on IP phones configuring this router but we can't success. I installed it under telephony-service using command below but it didn't work. The file copied in its directory.
IOS: c2801-ipvoicek9-mz.151-4.M4.bin or c2801-spservicesk9-mz.151-4.M4.bin
user-locale 1 U1 load CME-locale-tr_TR-Turkish-8.6.2.4.tar
network-locale 1 U1
How we can set the Turkish locale on every phone?
Kindly regards,
04-24-2012 12:51 PM
hi adnan,
you should try to set under ephone X the type of the phone...
e.g.
ephone 1
type 6961
telephony-service
create cnf-files
ephone 1
reset
- - or try following - -
telephony-service
cnf-file location flash:
cnf-file perphone
ephone-template 1
network-locale 1
user-locale 1
ephone 1
ephone-template 1
type 6961
telephony-service
create cnf-files
ephone 1
reset
let me know and don't forget to rate my post!
Konrad.
04-24-2012 12:56 PM
Hi Konrad,
Thanks for your answer but I already try them. And yes all types of phones set under ephone.
Kindly regards,
04-24-2012 12:59 PM
hi Adnan,
could you share the sh run?
thx
04-24-2012 01:30 PM
And that is
version 15.1
hostname CCME
boot-start-marker
boot-end-marker
enable secret 5 $1$G0L8$soz885829vmHcU5Hwxcol.
enable password xxxx
no aaa new-model
clock timezone GMT 3 0
dot11 syslog
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
voice-card 0
archive
log config
hidekeys
username xxxx privilege 15 secret 5 $1$NumO$Ju72.z/07t9Pm0Toby5/z.
interface FastEthernet0/0
ip address 192.168.2.10 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:/gui
ip route 0.0.0.0 0.0.0.0 192.168.2.99
tftp-server flash:/Phones/7914/S00105000300.sbn
tftp-server flash:/Phones/7971/apps70.8-4-1-23.sbn
tftp-server flash:/Phones/7971/cnu70.8-4-1-23.sbn
tftp-server flash:/Phones/7971/cvm70sccp.8-4-1-23.sbn
tftp-server flash:/Phones/7971/dsp70.8-4-1-23.sbn
tftp-server flash:/Phones/7971/jar70sccp.8-4-1-23.sbn
tftp-server flash:/Phones/7971/SCCP70.8-4-2S.loads
tftp-server flash:/Phones/7971/term70.default.loads
tftp-server flash:/Phones/7971/term71.default.loads
tftp-server flash:/Phones/7961/apps41.8-4-1-23.sbn
tftp-server flash:/Phones/7961/cnu41.8-4-1-23.sbn
tftp-server flash:/Phones/7961/cvm41sccp.8-4-1-23.sbn
tftp-server flash:/Phones/7961/dsp41.8-4-1-23.sbn
tftp-server flash:/Phones/7961/jar41sccp.8-4-1-23.sbn
tftp-server flash:/Phones/7961/SCCP41.8-4-2S.loads
tftp-server flash:/Phones/7961/term41.default.loads
tftp-server flash:/Phones/7961/term61.default.loads
tftp-server flash:/Phones/7911/apps11.8-4-1-23.sbn
tftp-server flash:/Phones/7911/cnu11.8-4-1-23.sbn
tftp-server flash:/Phones/7911/cvm11sccp.8-4-1-23.sbn
tftp-server flash:/Phones/7911/dsp11.8-4-1-23.sbn
tftp-server flash:/Phones/7911/jar11sccp.8-4-1-23.sbn
tftp-server flash:/Phones/7911/SCCP11.8-4-2S.loads
tftp-server flash:/Phones/7911/term06.default.loads
tftp-server flash:/Phones/7911/term11.default.loads
control-plane
voice-port 0/0/0
translation-profile incoming reject
cptone TR
timing hookflash-out 50
connection plar 1221
caller-id enable
voice-port 0/0/1
cptone TR
caller-id enable
voice-port 0/0/2
cptone TR
shutdown
caller-id enable
voice-port 0/0/3
cptone TR
shutdown
caller-id enable
mgcp profile default
dial-peer voice 201 pots
description Emergency
destination-pattern 9T
port 0/0/0
dial-peer voice 202 pots
port 0/0/2
dial-peer voice 100 pots
description PSTN_XXXXXXX
destination-pattern [0]..........
port 0/0/0
dial-peer voice 101 pots
destination-pattern [2-8]......
port 0/0/0
dial-peer voice 102 pots
port 0/0/1
dial-peer voice 103 pots
port 0/0/1
dial-peer voice 301 pots
destination-pattern 9................
port 0/0/1
dial-peer voice 302 pots
port 0/0/0
dial-peer voice 106 pots
port 0/0/2
dial-peer voice 107 pots
port 0/0/2
dial-peer voice 501 pots
destination-pattern 00.T
port 0/0/0
dial-peer voice 502 pots
port 0/0/1
sip-ua
telephony-service
max-ephones 30
max-dn 100
ip source-address 192.168.2.10 port 2000
system message CCME
cnf-file perphone
network-locale 1 U1
load 7914 S00105000300
time-format 24
date-format dd-mm-yy
max-conferences 4 gain -6
moh test10.wav
transfer-system full-consult dss
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template 1
softkeys idle Redial Newcall Gpickup
ephone-template 2
network-locale 1
user-locale 1
ephone-dn 20
number 1220
label 1220
name 1220
translate called 1
translation-profile incoming test
ephone-dn 21 dual-line
number 1221
ephone-dn 22
number 1222
pickup-group 1
label 1222
name 1222
ephone-dn 23
number 1223
pickup-group 1
label 1223
name 1223
ephone-dn 24
number 1224
pickup-group 1
label 1224
name 1224
ephone-dn 25
number 1225
pickup-group 1
label 1225
name 1225
ephone-dn 26 dual-line
number 1226
pickup-group 1
label 1226
name 1226
ephone-dn 27
number 1227
pickup-group 1
label 1227
name 1227
ephone-dn 28
number 1228
pickup-group 1
label 1228
name 1228
ephone-dn 29 dual-line
number 1229
pickup-group 1
label 1229
name 1229
ephone-dn 30
number 1230
pickup-group 1
label 1230
name 1230
ephone-dn 31
number 1231
pickup-group 1
label 1231
name 1231
ephone-dn 32
number 1232
pickup-group 1
label 1232
name 1232
ephone-dn 33
number 1233
pickup-group 1
label 1233
name 1233
ephone-dn 34
number 1234
pickup-group 1
label 1234
name 1234
ephone-dn 35
number 1235
pickup-group 1
label 1235
name 1235
ephone-dn 36
number 1236
label 1236
name 1236
ephone-dn 37
number 1237
label 1237
name 1237
ephone-dn 38
number 1238
pickup-group 1
label 1238
name 1238
ephone-dn 40
number 1240
pickup-group 1
label 1240
name 1240
ephone-dn 41
number 1241
label 1241
name 1241
ephone-dn 42
number 1242
pickup-group 1
label 1242
name 1242
ephone-dn 43
number 1213
label 1213
name 1213
ephone-dn 52
number 1212
label 1212
name 1212
ephone-dn 53
number 1216
label 1216
name 1216
ephone 1
mac-address 001C.58F9.A0B3
ephone-template 1
type 7911
button 1:35
ephone 2
mac-address 001D.A2F3.C7FA
ephone-template 1
type 7970
button 1:52
ephone 3
mac-address 001D.A2B7.EBCA
ephone-template 1
type 7911
button 1:34
ephone 4
mac-address 001E.7AC4.36C8
ephone-template 1
type 7911
button 1:22
ephone 5
mac-address 001D.A2B7.838F
ephone-template 1
type 7911
button 1o26,29
ephone 6
mac-address 001D.A2B7.EC18
ephone-template 1
type 7911
button 1:31
ephone 7
mac-address 001D.A2B7.EFC0
ephone-template 1
type 7911
button 1:30
ephone 8
mac-address 04C5.A44D.1B65
ephone-template 2
type 7911
button 1:20
ephone 9
mac-address 001B.5452.16FB
type 7961 addon 1 7914 2 7914
button 1:21 2m32 3m25 4m27
button 5m26 6m31 7m35 8m23
button 9m34 10m24 11m41 12m33
button 13m28 14m30 15m42 16m22
button 17m36 18m37 19m38
ephone 10
mac-address 001D.A2B7.EB65
ephone-template 1
type 7911
button 1o26,29
ephone 11
mac-address 001D.A2F3.B95E
ephone-template 1
type 7911
button 1:25
ephone 12
mac-address 001D.A2B8.1F5B
ephone-template 1
type 7911
button 1:33
ephone 13
mac-address 04C5.A44D.20E4
ephone-template 1
type 7911
button 1:42
ephone 14
mac-address 001D.A2F3.C4E1
ephone-template 1
type 7911
button 1:38
ephone 15
mac-address 64AE.0C5F.8A27
ephone-template 1
type 7911
button 1:32
ephone 16
mac-address 001D.A2F3.C723
ephone-template 1
type 7911
button 1:36
ephone 17
mac-address 001D.A2B7.669B
ephone-template 1
type 7911
button 1:27
ephone 18
mac-address 001D.A2B7.EEFE
ephone-template 1
type 7911
button 1:24
ephone 19
mac-address 001C.58F9.A109
ephone-template 1
type 7911
button 1:37
ephone 20
mac-address 0008.3031.BBBF
ephone-template 1
type 7911
button 1:23
ephone 21
mac-address 001D.A2F3.C2AA
ephone-template 1
type 7911
button 1:53
ephone 22
mac-address 001D.A2F3.BA28
ephone-template 1
type 7911
button 1:28
ephone 23
mac-address 0008.3031.B598
ephone-template 1
type 7911
button 1:40
ephone 24
mac-address 001D.A2B7.F049
type 7911
button 1:43
ephone 25
mac-address 0008.3031.B5EC
ephone-template 1
type 7911
button 1:41
ephone 28
mac-address 001D.A2B7.F97F
type 7911
button 1:53
line con 0
line aux 0
line vty 0 4
password xxxxx
login local
transport input all
scheduler allocate 20000 1000
end
CCME#
04-24-2012 01:37 PM
hi adnan,
you have assigned to all ephones the ephone-template 1 (except the ephone 8)
you must configure al ephones with ephone-template 2...
please check your config...
ephone-template 1
ephone-template 2
network-locale 1
user-locale 1
Konrad
dont forget to rate my post... if it was helpful...
04-24-2012 02:11 PM
Automatic localization doesn't really work.
You need to use the traditional method, that is to exact files using archive command. Then configure tftp-server for the approapriate model.
You can use debug tftp event to check the phone requesting and getting local files.
04-24-2012 11:12 PM
hi,
if u enter the following command, it takes some time, because the files will be xtracted automatically.
so you don't have to archive them manually. or i'm wrong?
i tested it with CME 8.6 and 9.0 - but with 69XX Phones... so i don't know if it's working with 79XX...
Konrad.
04-25-2012 12:57 AM
Hi Konrad,
Did it work with 69XX phones. I mean after that configuration (user-locale 1 U1 load CME-locale-tr_TR-Turkish-8.6.2.4.tar), did 69XX phones work with Turkish Locale?
I' m using C2801 and Cisco 79XX phones. I'm already using user-locale command under telephony-service and tftp's debug outputs below while I reset the 7911 IP phone. Any Idea?
CCME#
Apr 25 07:52:37.931: %IPPHONE-6-UNREGISTER_NORMAL: ephone-8:SEP04C5A44D1B65 IP:192.168.2.187 Socket:7 DeviceType:Phone has unregistered normally.
Apr 25 07:53:23.550: TFTP: Looking for CTLSEP04C5A44D1B65.tlv
Apr 25 07:53:23.670: TFTP: Looking for SEP04C5A44D1B65.cnf.xml
Apr 25 07:53:27.669: TFTP: Looking for SEP04C5A44D1B65.cnf.xml
Apr 25 07:53:31.669: TFTP: Looking for SEP04C5A44D1B65.cnf.xml
Apr 25 07:53:35.669: TFTP: Looking for SEP04C5A44D1B65.cnf.xml
Apr 25 07:53:45.503: %IPPHONE-6-REG_ALARM: 22: Name=SEP04C5A44D1B65 Load= SCCP11.8-5-2S Last=Reset-Reset
Apr 25 07:53:45.547: %IPPHONE-6-REGISTER: ephone-8:SEP04C5A44D1B65 IP:192.168.2.187 Socket:13 DeviceType:Phone has registered.
CCME#
Adnan.
04-25-2012 01:05 AM
hi Adnan,
i've tested it successful on an 2921 with Version 15.1(4)M3 (CME 8.6) and 2901 with 15.2(2)T1 (CME9.0) with 6945 and 6961 Phones. i've done it with languages DE and IT - not tested with TR!
What i've done was following:
1) create folder "its" if not present "mkdir flash:/its"
2) copy tftp: flash:/its/CME-locale-de_DE-German-8.8.2.4.tar
3) copy tftp: flash:/its/CME-locale-it_IT-Italian-8.8.2.4.tar
4)
telephony-service
cnf-file perphone
user-locale 1 DE load CME-locale-de_DE-German-8.8.2.4.tar ! when you enter this cmd it takes some time to extract the files -> it does the system automatically
user-locale 2 IT load CME-locale-it_IT-Italian-8.8.2.4.tar
network-locale 1 DE
network-locale 2 IT
ephone-template 1 ! german template
network-locale 2
user-locale 1
ephone-template 2 ! italian template
network-locale 2
user-locale 2
ephone 1
ephone-template 1
type 6945 !! important that the phone takes the new lang files
!!! IMPORTANT
telephony-service
create cnf-files
reset the phones...
Konrad
