05-30-2013 07:32 AM - edited 03-16-2019 05:36 PM
I just upgrade 7.1.5.35900-7 and notice the locals are
cm-locale-combined_network-7.1.5.1000-1.cop
cm-locale-da_DK-7.1.5.1000-1.cop
cm-locale-de_DE-7.1.2.3000-1.cop
cm-locale-en_GB-7.1.2.3000-1.cop
cm-locale-es_ES-7.1.2.3000-1.cop
cm-locale-fr_FR-7.1.2.3000-1.cop
cm-locale-it_IT-7.1.2.3000-1.cop
cm-locale-sv_SE-7.1.2.3000-1.cop
cmterm-IPComm-directorywizard.cop
localeinstaller
any harm to align them to 7.1.5.1000 ?
thanks
Solved! Go to Solution.
05-30-2013 08:50 AM
They should be aligned with compatible locale version, everytime you upgrade CUCM you need to ensure locales are compatible and in most cases need to be upgraded.
HTH,
Chris
05-30-2013 08:07 AM
Hi Louis,
Are u facing some issue while using these locales after u did the upgradation?
regds,
aman
06-03-2013 04:54 AM
Hi Aman,
No issues so far and don't want to wait for issues to upgrade :-)
thanks
05-30-2013 08:50 AM
HTH,
Chris
06-03-2013 04:54 AM
Thank you Chris. I will do them
06-13-2013 06:08 AM
Hello
since i did them, the rtmt alerts are empty :-(
any idea?
thanks
06-13-2013 06:27 AM
Hi Louis,
Can u try restarting Cisco AMC service?
regds,
aman
06-13-2013 06:46 AM
Hi Aman,
i ve tried that...
i found a similar issue but it s on unity. i gave it a go on my lab no luck...
thanks
RTMT alerts missing after upgrade from 7.1(3) to 8.5(1).
Symptom:
After upgrading UC from 7.1(3) to 8.5(1) RTMT no longer shows any of the alerts under either System or UnityConnection.
Workaround:
*WARNING* This will remove any custom alerts you had configured. If this is ok then use these steps to recreate the default alerts.
ssh to the publisher
run sql ccm delete from scratch where name like 'Ris%'
Go to "Cisco Unified Serviceability"
Tools -> control center - network services
restart "Cisco AMC Service"
After AMC service is restarted you should be able to launch RTMT and see the default alert settings.
06-13-2013 07:40 AM
Hi Louis,
I could not find any other POST/Bug related to your RTMT problem.
Can u open a new thread with changed subject and see if others can help us ?
regds,
aman
06-19-2013 12:23 AM
New discussion opened
