04-28-2011 09:27 PM - edited 03-16-2019 04:43 AM
Trying to configure Location based CAC using RSVP, have done the configuration but it always says not enough bandwidth even though i have given ample bandwidth on the serial interfaces.
Steps used to configure:
Configured MTP on the HQ and Branches-Registered to HQ and Branch DP.
Assigned the HQ and Branch MTPs to respective DPs using MRGL.
Created Location for HQ and Branch and assigned to respective DPs. Reservation is mandatory.
Codec used on between the regions is G729.
Not sure what I am missing.
Vinay
05-05-2011 11:55 PM
Did you configure the RSVP Agent properly? RSVP Agent is MTP with RSVP enabled. You also need to configure other gateways on the path to support RSVP
Check the following links if that helps
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/interop/int_rsvp.html
- abu
05-06-2011 03:29 AM
Did you also remove the G711u codec and add codec pass-through from/to the dspfarm profile?
Can you attach the show runs from the HQ and Branch GW's?
