Location CAC E1 MGCP CUCM 6.1(1)
s.kho
I have got the following:
Location A:
A Cisco E1 Gateway connected to an Alcatel PABX.
Location B:
Another Cisco E1 Gateway connected to another Alcatel PABX.
These two Cisco gateways have connection over the IP WAN.
These gateways are controlled by MGCP with the E1s configured with QSig to interface to the Alcatel PABX.
Can I use CUCM 6.1(1) location to controll how many calls originate from PABX in location A destined to PABX in location B.
matthewpage
Level 3
Level 3
Hi, Yes you can do this. I think you need to assign a device pool to the gateway though as i dont think you can assign a location directly to a gateway. You then just need to assign the maximum amount of bandwidth required.
