03-07-2013 05:47 AM - edited 03-16-2019 04:07 PM
When CAC (Call Admission Control) Locations & Regions are activated on CUCM and there's not enough bandwidth available for a new call the 79XX phones displays 'Not enough bandwidth available".
This seems not to be the case for the 69xx and 89XX types of phones. There you get an announcement "the call can not be completed". Is this a bug in the phoneload?
The same is true for the EX60/90 (TE & TC), MX, C and SX series (TC) of video endpoints that can be registered to CUCM. Also a phoneload bug?
Very confusing for the user who thinks there's an outage on the PBX system or PSTN...
rgds, Geert Folens.
Solved! Go to Solution.
03-07-2013 11:15 AM
I see the same behavior, on a 6945 I get a busy tone same as an 8961 phone with the message "Unable to setup call". Digging into this I found that this was done on purpose (CSCtt04460). What you have to do to show a more meaningful message on the phone is change the Cisco CallManager service parameter "Out-of-Bandwidth Text" from the default of "Not Enough Bandwidth" to anything else other than the default value. If the default value is used the "Unable to setup call" is shown. If you change the service parameter to "Not Enough Bandwidth2" you will see "Not Enough Bandwidth2" on all the phones.
03-07-2013 07:37 AM
What CUCM version and what phone load/phone model of 79XX are you seeing this with?
03-07-2013 07:40 AM
CUCM v8.6(2)su2
7965 load:SCCP45 9.2.3
6941: SCCP 9.3.1.3
8941: SCCP 9.3.2.11
03-07-2013 07:43 AM
Thank you, I'm trying this out now to see if I get the same result.
03-07-2013 11:15 AM
03-07-2013 10:57 PM
And what about the video endpoints running TC/TE software?
03-08-2013 06:11 AM
The TC/TE endpoints were originally made by tandberg so they likely do function differently. If they function like the 89XX/69XX phones I would say they are most likely working as intended.
