Lock IP Phone other than extension mobility
hi,
I have a requirement for locking IP Phone when a user leaves desk or something. though I have extension mobility implemented but it is becoming difficult everytime to put PIN/PWD, so are there any other option which can be used?
Thanks in advance.
Regards.
5 Replies 5
paolo bevilacqua
Start mentioning system type and version you're using.
I am using CUCM 8.5
There are third-party applications that yoiu can search about.
Hi Gautam,
You need to go for third party application .
http://www.andtek.com/communications-products-lockout.html
regds,
aman
Pranjol Saikia
Level 4
Level 4
