Log files in SX/EX/C codecs
Have been looking for some explaination of what events and inforamtion is contained in each one of the log files.  looking to do some troubleshooting and I would like to try and look at the right file and not have to sequentially look at each file.
Is there a list?
Thanks.
Enrico Conedera
Here is a list of the log files and descriptions:
Audio 0-8:  One log per AUDIO DSP, if they are empty it is a good sign.
Application.log: Debug and application info. Here you will find H.323 messages, call setup etc.
Main.log: Process monitoring, typical you should look here if the system boots.
All.log:  includes all logs. Nice for looking at something chronologically
Scriptbuffer.xml: Is used for video. Includes xml info about communication between video controller and video subsystem.
Statedump.xml: Pretty much the same as scriptbuffer.xml.
Video0-9: Is logs for the video ARM processors, typically transcoding and mixing of video signals.
Videocontroller.log: Is for the video controller. Typically tells the system which resolution to encode and decode. 30 and 60 etc.
Videogw0-9: Is the DSP logs. The DSPs will do encoding and decoding of video.
VPE0-9: Video Processor Engine. The video inputs which also is connected to the FPGAs. Typically problems with the video inputs and FGPA.
Enrico,
This is good information.
Specifically, I have a C20 running TC6.2.1 that seems to be loosing pairing with its touch panel and I am wondering which log to look at and if there is a specific string to be looking for.
