449
Highlighted
Enthusiast
Log Partition increasing - CUCM 11.5
We have set Low watermark level as 90 & High as 95. currently, we are reaching 90% and we are getting below alert.
If it will cross the upper limit then whether the logs will be purged or not? Thanks.
 UsedDiskSpace : 90
MessageString : Common Disk utilization hits LWM!
AppID : Cisco Log Partition Monitoring Tool ClusterID :
NodeID : cucm-1
 TimeStamp : Sun Aug 05 03:44:46 EEST 2018.
The alarm is generated on Sun Aug 05 03:44:46 EEST 2018.CUCM
3 REPLIES 3
Highlighted
Re: Log Partition increasing - CUCM 11.5
A lot of topics on your issue :- )  link
br Oleksandr
Highlighted
The logs will be purged when they will cross the limit.
br Oleksandr
Highlighted
Collaborator
The logs will be purged automatically once it crossed the threshold set. You can also reduce the value so that the purging starts when the value you set is reached or manually save the logs needed and delete them.
Rajan
Pls rate all helpful posts
Content for Community-Ad
Future of Work Virtual Summit Day 5
Cisco COVID-19 Survey
