08-11-2021 03:49 AM
Hi there,
I have a phone connected to PABX - E1 voiceport to Cisco Voice Gateway (2900 - IOS 15-3).
Pots and VOIP dial-peer configured with SIP trunk to SIP Service provider.
Is it possible to configure dial-peer commands to block only calls where ANI is 00xx and DNIS is +xx from being sent to the SIP trunk?
All other combination of calls to DNIS +xx should be allowed.
I have checked logic for call-block (dial peer) command but seems limited to one argument and cannot combine to block ANI and DNIS together.
Thanks in advance
Solved! Go to Solution.
08-12-2021 10:48 AM - edited 08-12-2021 11:04 AM
You should be able to reach this outcome with the COR functionality in IOS. It’s a matter of crafting dial peers and assigning them to proper cor lists to achieve the restrictions that you aspire.
Please see this document for details on how to set this up.
https://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/42720-configuring-cor.html
08-11-2021 10:41 AM
Can you please share with us what end result you want to achieve with this? Aka please describe the outcome on a logical level, not technical what you want to do.
08-11-2021 11:39 PM
Hi there,
Many thanks for reply back.
The outcome is to send SIP response back to SIP service provider when a user dials combination of ANI is 00xx and DNIS is +xx only.
7852272471
Example user dials from 0044123456789 and dials +446789012435 - call rejected
user dials from 0033123456789 and dials +446789012435 - call allowed
Therefore only combination of number starting with 044 to +44 is rejected.
Hope this clarifies my request.
Thanks in advance.
08-12-2021 03:09 AM
Maybe I'm daft, but I still don't get it. The ANI is someone on your end that calls to the DNIS number on PSTN or am I reading your outline backwards, ie that the call originates from PSTN and is destined to you? Can you please describe the call direction?
08-12-2021 03:43 AM
08-12-2021 08:17 AM
Hi there,
Many thanks for the above posts and the above is the logic. Apologies if I caused confusion.
Requirement is for example phone with calling number 0044123456789 and dialed number +446789012435 to be rejected not on CCUM but on the Voice Gateway.
However I want for example calling number 0032123456789 and dialed number +446789012435 to be allowed to route call to SIP trunk on the Voice Gateway,
I hope this clarifies request.
08-25-2021 11:34 PM
Hi Roger & Mohammed,
Really appreciate the replies above and will discuss with team whether either solutions above can be applied to help resolve issue.
Thanks again for all posts.
