560
ifthi.cisco
Beginner
Long beep sound in UCS C220 Server
Hello All,
We have recently upgraded our CM server from MCS to UCS C220. All is working well since 3 weeks. However, since the past three days the UCS server is giving long beep sounds. In the CIMC console its showing as Severe Fault and in Storage Slot 1 and physical Drive 2, the status is "Foreign Configuration" and Health status is "Moderate Fault". However, when we check the status of the light on  the physical drive, its still green and not amber. So is it there a problem with the Harddrive?
Pls find the screenshot attached.
1 REPLY 1
Sreekanth Narayanan
Hey there. I don't think you'll get a reply on this forum because it looks like this is a fault on the UCS server itself, and not on the Unified Communication application that runs on the UCS server. Please re-post this discussion to the board which discusses UCS servers. You'll get a reply there.
Create
Recognize Your Peers
Content for Community-Ad
