09-20-2022 04:33 AM
Yesterday, I ran an export job that still showed a status as running this morning.
I stopped that job and then deleted it.
Next, I decided to run a completely different export job that is now stuck in a pending status.
I see no other jobs running that may cause that.
Could CUCM still think yesterday's job is still there and running?
How would you check for that?
Is there some sort of command line on the pub that will show what's going on?
I'm thinking that I may have to restart tomcat service on the pub or maybe reboot the pub if a tomcat restart doesn't fix it.
Solved! Go to Solution.
09-20-2022 05:37 AM
Given those symptoms, I would start by stopping all jobs and restarting the Bulk Provisioning Service. Then try running a simple job to see if it completes. If that does not work, let us know.
Maren
09-20-2022 05:37 AM
Maren
09-20-2022 11:50 AM
restarting Bulk Provisioning Service was the fix! Thanks Maren!
