losing caller ID after long call flow
tato386
Level 6
Level 6
I am losing caller ID info at the end of a long call flow which looks like this:
- call comes in to UC500 via PSTN SIP trunk
- reception answers and blind transfers to 4 digit DN on CUCM via internal SIP trunk
- CUCM DN is a CCX application trigger
- CCX script plays prompt and redirects call to different CUCM DN
- agent on CUCM phone sees internal extension of UC500 reception as calling party
What do I need to do/check/configure/debug so I can get the original PSTN phone number to show on the agent phone?
Diego
Hi Diego,
What happens if the reception sends the call directly to s CUCM extension instead of a CTI RP?
Can you please attach the output of a debug ccsip message?
Please let me know.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hello Carlo,
The result is the same when the call is transferred to a CUCM extension so I guess the CCX doesn't really come into play yet.  The CUCM has a CUBE for PSTN SIP trunks so I tried debugs with xfer directly to CUCM from UC500 and then thru CUBE first then to CUCM and result are still the same.  I tried to sanitize the debugs a bit so you will see outside caller as PSTN5551212 calling DID5551212 which is 8118 on UC500.  Then 8118 transfers to CUCM 471 which cannot see original caller from PSTN5551212.
