LSI_RAID_LD_Degraded
Jon Pope
Is this an indication of a drive that needs to be replaced or could this be due to a recent reboot.  I rebooted the system and about 10min after reboot completed i got the following error.
At Fri Jan 25 06:27:38 CST 2013 on node , the following HardwareFailure events generated:
hwStringMatch : Aug  3 06:57:32 CUCM01 daemon 4 Director Agent: LSI_RAID_LD_Degraded CUCM01 State change on LD 02 from OPTIMAL(3) to DEGRADED(2) Sev: 3.
AppID : Cisco Syslog Agent
ClusterID :
NodeID : CUCM01
TimeStamp : Fri Jan 25 06:27:06 CST 2013
I am finding it difficult to dig into the volumes and volumes of information to find specifics.  If someone could point me in a direction i would be most thankful.
Aaron Harrison
What kind of a server might that be?
Have you done a 'show hardware'?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Thank you so much.
MCS-7825-i4
admin:show hardware
HW Platform       : 7825I4
Processors       : 1
Type             : Intel(R) Core(TM)2 Duo CPU     E8400 @ 3.00GHz
CPU Speed        : 3000
Memory           : 4096 MBytes
Object ID         : 1.3.6.1.4.1.9.1.746
OS Version       : UCOS 4.0.0.0-45
Serial Number     : KQ063F0
RAID Version     :
Raid firmware version: 1.27.86.00
Raid Bios version: 6.1a.00.00
BIOS Information :
IBM IBMBIOSVersion1.44-[M9E144AUS-1.44]- 06/11/2009
RAID Details     :
LSI Logic IR Configuration Utility 2.00.15
Read configuration has been initiated for controller 0
Controller information
Controller type                         : SAS1064E
BIOS version                           : 6.1a.00.00
Firmware version                       : 1.27.86.00
Channel description                     : 1 Serial Attached SCSI
Initiator ID                           : 112
Maximum physical devices               : 62
Concurrent commands supported           : 277
Slot                                   : 0
Bus                                    : 1
Device                                 : 0
Function                               : 0
RAID Support                           : Yes
IR Volume information
IR volume 1
Volume ID                               : 2
Status of volume                       : Okay (OKY)
RAID level                             : 1
Size (in MB)                           : 237464
Physical hard disks (Target ID)         : 4 3
Physical device information
Initiator at ID #112
Target on ID #3
Device is a Hard disk
Enclosure #                             : 1
Slot #                                 : 1
Target ID                              : 3
State                                   : Online (ONL)
Size (in MB)/(in sectors)               : 238475/488397168
Manufacturer                           : ATA
Model Number                           : WD2502ABYS-23B7A
Firmware Revision                       : 3B05
Serial No                               :     WD-WCAT1H110594
Drive Type                             : SATA
Target on ID #4
Enclosure #                             : 1
Slot #                                : 0
Target ID                               : 4
Manufacturer                           : ATA
Serial No                               :     WD-WCAT1H110768
Drive Type                             : SATA
Enclosure information
Enclosure#                               : 1
Logical ID                             : 5005076b:064d2f14
Numslots                               : 4
StartSlot                               : 0
Start TargetID                         : 0
Start Bus                               : 0
