01-25-2019 02:04 AM - edited 03-17-2019 02:00 PM
Just wondering if someone could point me in the right direction... we have a voice message that is played when external calls come through to our main office line, during the message callers are given the options of press 1 for this and press 2 for that etc.
Now, two questions...
1. How do we change that voice message? Is it just a matter of going in to the voicemail options on the line the main number hits and changing the message or is it done somewhere else?
2. The voicemail needs to be changed because we need to add more options... where are these options configured? For example, if a caller presses 1 how do we tell Cisco Call Manager which number to redirect to? I'm sure I've seen it and configured it in the past but I've totally forgotten.
Thanks for any help.
01-25-2019 02:45 AM
hi,aquaium
: you can change the greeting to personal greeting. where you can create a new call handler and using your custom greeting.
2、The voicemail needs to be changed because we need to add more options... where are these options configured? For example, if a caller presses 1 how do we tell Cisco Call Manager which number to redirect to? I'm sure I've seen it and configured it in the past but I've totally forgotten.
see the attachment
01-25-2019 02:46 AM
01-25-2019 03:07 AM
Thanks for the reply.
I can see where the current recording is but how do we change that recording to a new one or even better just create a new recording in case we need to go back to the old recording? Does it mean doing the recording via the computer or the telephone?
01-25-2019 03:32 AM
01-25-2019 04:06 AM
Sorry but where is the Media Master Options menu? I can't find it anywhere in the Cisco Unity Connection Administration page. Am I missing something?
01-25-2019 07:08 AM
01-25-2019 08:06 AM
Great video. Thank you.
One further question... how do I get around this Java issue? I can't load the Java applet to play/record messages with any of the current browsers.
01-25-2019 08:34 AM
Unfortunately CUC when it used Java for the media player was extremely picky regarding the versions, recent versions use HMTL5 to avoid that.
You'll have to review the System requirement guide from your CUC release and try the Java release it's mentioned as supported (or the closest one you can find), or use the greeting administrator which has already been mentioned.
01-29-2019 04:32 AM
How do I access the greeting administrator?
01-29-2019 04:44 AM
Hi there
you can create greeting administrator in CUC. Below is an easy how to do guide
https://www.netcraftsmen.com/configuring-greetings-administrator-without-new-routing-rules/
Hope this helps
Cheers
Rath!
***Please rate helpful posts***
