make conference international call by FXO code
Yazen Alaa
Dear All
CUCM 7.1.5 , Voice gateway using H323 , Analog lines port 2/0/0
I want to make international if i am out side the company  by my mobile through my extension :
My mobile calling > FXO code : DID 3456 > open line to make international .
I did in voice gateway :
num-exp 3456 64
dial-peer voice 250 pots
destination-pattern 64
port 0/2/0
dial-peer voice 251 pots
port 2/0/0
in CUCM
route pattern :  64.!
when i make dial from my mobile to 22923456 > it opens new line then dial 64 then 00967XXXXXXXXXXX > it gives me " your number invalid "
- how to solve this issue ?
- How the configuration will be in CUCM and Voice gateway h323 ?
thanks all
5 Replies 5
Jaime Valencia
Review the CUCM features and sevices guide, the mobility option is what you're looking for.
Explanation and configuration is there.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi jaime
i am not talking about mobility option , my scenario is
if i am outside i want to make conference international call by calling DID extension 3456 , then open new line or code then put 0032XXXXXXXXX  ,
outside company from my mobile > DID 2292-3456 > then open line in FXO with code 022 then > put international number 00!
how it will be ? in CUCM and voice router or gateway with dial peer and route pattern ?
plz any reply ?
Any professional can help me ?
thanks
Yazen Alaa
your answer is very important for me
thanks
