04-30-2007 10:14 PM - edited 03-14-2019 09:14 PM
?Can I forced to use an account codes in a CCME v4.0 and Call Detail Record (CDR) field entry to make a call?
05-01-2007 04:01 AM
Yes CCME supports Account so I guess it would copy that into CDR.
05-01-2007 12:29 PM
It mean that the CCME 4.0 can be configured with restrictions code for each user. An another words, ?can I confiure some users can make a international calls and other not be done?
05-01-2007 12:46 PM
Sure, you have three methods:
1 - COR list. you permanently block certain calls from certain phones
2 - PIN login & afterhours. Once logged with a per-phone pin in you can dial certain patters and also define a time schedule for this to happen.
3 - Custom steering digits. You create special prefixes to allow certain calls and this code is given to ppl kind of like an account number.
1 & 2 are explained in the sysadm guide and others CCO documents. 3 - is not but easy to figure out.
05-01-2007 05:35 PM
05-01-2007 07:47 PM
Thanks so much, I?ll check the file and we?ll make the test with our lab equipments.
Manuel Dominguez
08-11-2007 05:20 AM
Dear sir
i tried to use it in new IOS that used application--> service FAC --> tftp://x.x.x.x/fac.tcl and define min-uid and define this service under dial-peer but it did not work with CME 4.0(3)
thank you
kindest Reagards
08-11-2007 05:22 AM
Please include your dial-peer and service configuration.
08-12-2007 02:57 AM
hello
this is confgiguration
tftp-serve flash:FAC/acctfixedpin.tcl
application-->Service FAC tftp://x.x.x.x/FAC/acctfixedpin.tcl
param uid-len 5
then go to dial-peer that need FAC
dial-peer voice 7 pots
service FAC
destination-pattern 905.......
corlist outgoing FAC-required
port 0/1/0
dial-peer cor custom
name All-users
name FAC
dial-peer cor list Users
member All-users
dial-peer cor list FAC-required
member FAC
08-12-2007 03:26 AM
That doesn't work because "service" configuration works for inbound DP only.
To make so the IP phones can reach the FAC service, you need to configure a voip DP in "loopback mode":
dial-peer voice 77 voip
service FAC
incoming called-number 905.......
session target ipv4:10.1.2.3 <--- PUT ROUTER ADDRESS HERE, PREFERABLY LOOPBACK INTERFACE
codec g711ulaw
dtmf-relay rtp-nte
no vad
