07-11-2011 11:19 AM - edited 03-16-2019 05:53 AM
Hey folks. Running CUCM 8.5 and I have a new Publisher and new Subscriber. Also, I'm new to CUCM.
I would like my phones to all register to the Sub. They're all currently registered to the Pub.
I also want to make sure the Pub will take over if the Sub goes down.
Under Serviceability/Service Activation, the Sub currently does not have any services running.
I also noticed that, on the Pub (CM group configuration) the Publisher is the only server available.
I assume I only have to enable the CM service on the Sub to make it show up in the CM group, then put the Sub higher than the Pub.
Am I close?
Thanks!
Ven
Solved! Go to Solution.
07-11-2011 11:30 AM
Hi there,
Yes, once you activate the CM service on the sub, it will appear as an option in the CM group config. Then as you sad just ensure it is higher in the CM group to ensure phones will use it as it's primary call processing server.
HTH,
Chris
07-11-2011 12:56 PM
Hey Ven,
No worries my friend Sorry about that!
You don't have to change anything in the Device Pool if you are using the default DP
My reference was only that this is one place (of many) where we can reset the phones that relate
to a certain CCM Group/Device Pool relationship.
You can also just do a device search and reset all via Device>Phone when you are ready to move the
registrations over.
Cheers!
Rob
07-11-2011 11:30 AM
Hi there,
HTH,
Chris
07-11-2011 11:35 AM
Chris:
Thanks for the info. One more question. What does this do to the phones that are currently registered to the Publisher?
We're still pre-production, but the onsite folks are using a few of the phones for testing.
Will this cause the phones to bounce?
Rock on Chris!
Ven
07-11-2011 12:15 PM
Hi Ven,
Just to fill in for Chris for a moment (big shoes to fill +5 "C")
The phones will not reset/bounce until you manually ask them to, so
you are in control here. Once you change the CCM Group you would then
normally change the reference to it in the Device Pool and reset the phones
to push the registration over to the Sub.
Cheers!
Rob
07-11-2011 12:30 PM
+5 for the great response!
Chris
07-11-2011 12:47 PM
Whoah there Rob...
Let's pretend I don't know what I'm doing (cuz I don't)
I didn't realize I had to change the device pool.
I have everything in the "default" pool. Do I have to change the pool?
ven
07-11-2011 12:56 PM
Hey Ven,
registrations over.
Cheers!
Rob
07-11-2011 12:59 PM
Rob:
Thank you. That makes a lot of sense.
Ven
