1232
Beginner
Map external Caller-id to personal address book- CUCM 7.1 & 8.6
Hi All,
I need to map external caller id to personal address book if possible.     What I need is if caller with the Mobile number 0XXXXXXXX calls internal within Cluster, and user has the caller in his personal Directory ( 79XX Phone), then the caller-id of the external caller shows on display. By default just it shows the number.
Can it be done on CUCM 7.1.3 or 8.6.2
Hamed
1 ACCEPTED SOLUTION
Hall of Fame Cisco Employee
Re: Map external Caller-id to personal address book- CUCM 7.1 &
No, we don't offer such feature, look at Paolo's script for that
java
if this helps, please rate
1 REPLY 1
java
Content for Community-Ad
August's Community Spotlight Awards
