10-24-2020 11:36 AM
A customer of ours has 8 FXO lines and 50 IP Phones/DNs, They wan to map 6 of the FXO to specific DNs.
Example: Voice port 0/0/1 to be used only via DN 2001, now the Inbound part is ok but the outbound is confusing me.
I followed this link:
But it didn't work, when dialing 9xxxxxx it gives a busy tone from the 9 digit.
Here's the config:
dial-peer voice 10 voip translation-profile incoming Phone10 answer-address 2010 ! voice translation-profile Phone10 translate called 3 ! voice translation-rule 3 rule 1 /^9/ /39/ ! dial-peer voice 39 pots destination-pattern 39T port 0/0/2
Solved! Go to Solution.
10-25-2020 10:43 PM
dial-peer cor custom
name COR1
name COR1
dial-peer cor list 1
member COR1
dial-peer cor list 2
member COR2
dial-peer voice 29 pots
corlist outgoing 1
destination-pattern 9T
port 0/0/1
corlist outgoing 2
port 0/0/2
voice register pool 18
cor incoming 1 default
voice register pool 19
cor incoming 2 default
10-24-2020 06:31 PM
Do u need to send 39 to PSTN ? if yes then use the command "forward-digits all" under dial-peer. Else only the digits dialled after 39 will be sent to PSTN asper this dial-peer configuration.
10-24-2020 06:42 PM
No I don't need to send 93, they're only used to distinguish the calls from 2010.
10-24-2020 10:13 PM
is this a CME or CUCM setup ?
10-25-2020 12:08 AM
CME
10-25-2020 12:12 AM - edited 10-25-2020 08:57 AM
As it is CME you can disregard what I wrote as it is from what I know not applicable. With CME your options are somewhat limited and straight up I can’t think of a way to do what you ask for. But then again CME is not one of my usual systems to work in.
10-25-2020 01:45 AM
Use COR.
dial-peer 1 for 0/0/1 in COR 1 and extension 2001 has only access to COR 1
dial-peer 2 for 0/0/2 in COR 2 and extension 2010 has only access to COR 2.
10-25-2020 05:42 AM
Can you help me with a sample config ?
10-25-2020 08:51 AM - edited 10-25-2020 08:55 AM
Google COR IOS configuration. I’m sure you will find ample examples and you’ll learn while doing it.
In fact the link I posted earlier contains information about how to set up COR.
10-25-2020 10:43 PM
name COR1
name COR1
member COR1
member COR2
corlist outgoing 1
port 0/0/1
corlist outgoing 2
port 0/0/2
11-01-2020 10:55 PM
I configured this remotely and the customer was satisfied!
Thank you
10-24-2020 11:54 PM - edited 10-25-2020 12:04 AM
You’ll need to have a setup to match the inbound call from CM by calling number and then map that call to use a specific FXO port. Have a look at this excellent document for ideas on how to do this. https://www.cisco.com/c/en/us/support/docs/voice/ip-telephony-voice-over-ip-voip/211306-In-Depth-Explanation-of-Cisco-IOS-and-IO.html
In particular Dial-Peer groups would be what you should look at.
