Mapping PSTN cause codes with the corresponding SIP Cause codes
rajasekarvs
We are trying to integrate the Asterisk dialer through SIP trunk with Cisco 3845 gateway running c3845-adventerprisek9-mz.124-15.XZ2 IOS image on the same. I`m facing some issues in my attempt to track the Special Information Tones (SIT) on this deployment ,where in the normal disconnect cause code 16 for all the calls are being reported to the Asterisk dialer on the SIP trunk. Ideally it should be the different cause codes for each of the SIT type. Could somebody please advise ,if this is supported with the Cisco Voice gateway platforms? This is kind of urgent for us.
Raj
39 Replies 39
Can you post the trace of Q.931 and SIP ? I'd like to see how this is handled.
I think the GW should forward both a 4xx message as the call has ultimately failed, and the PI of inband announcement or tones. So the OGW has the choice of what to do with their user.
On the other hand I understand that in your case it's automated calls and not users so all what you wanted is the error message.
Hey ,
I don`t think I can get the gateway traces ,as I`m trying the call with our production gateway that`s processing the live calls and we don`t have a test AS5400...:(
You are right ,it`s all the automated calls from the dialer and we just wanted the error message back to write the call result on to the database.
Raj
Just briefly enable debug q931 for a single PRI and the ccsip message, that is not impacting to CPU. You can always log debug to buffer for even a better way.
You will need to show these to the TAC if you want the issue resolved on the ISR.
I`m sorry for the delayed response.Lemme try getting the debugs from the gateway and I`ll upload them to this thread.
Raj
Was there ever an answer from Cisco why the unallocated cause code was not forwarded via SIP?  I have the same situation with a 15.1(3) 3845  to a  8.5 CUCM - the carrier sends an unallocated back in a progress message on an outbound call but actually goes on to connect the call for about 60 seconds.  The gateway never forwards what should be a 404 (I would think), but instead sends a series of "183 Session Progress" messages to the CUCM and the caller just hears ringback.  Now I know the carrier should disconnect the call straight away in a perfect world, but getting them to change will likely be next to impossible.  We do have "Signalling forward unconditional" already configured.  Is there something we can do to force the forward of the unallocated/404?
Art
If acceptable in your case, can you try
voice call disc-pi-off
that makes the VG to disconnect imediately even in presence of PI.
Thanks Paolo for the quick reply.  I gave it a go, but unfortunately that didn't work on this one.
Art
By coincidence, today I needed this one too and doesn't work.
I keep trying.
I asked PDI too.  Will let you know if they send anything back....
Turns out my issue is an IOS bug, from Cisco:
There is a documented IOS bug on this, CSCta66956, which was supposed to fix that issue in your current IOS version 15.1(3)T. However, looking at the internal bug notes for CSCta66956, I found that an IOS file build error happened and the fix code was removed from the IOS versions that were supposed to include that fix. For this problem, a new software defect was raised, CSCtq49731, and the fix code was added to public IOS versions in train 15.2T.
BTW, if you look for bug CSCtq49731 in Cisco's web site, you will see that it specifically mentions "Cause i = 0x82E46C", however this bug actually applies to all cause codes.
Cheers!
Art
