Matching incoming dial-peer
Evgeny Andreev
Hello!
There are two different types of calls
1. Calling number 9. - variable length (dial-peer 1)
2. Calling number 92XX - fixed 4 digit length (dial-peer 2)
I need to separate them with two different incoming dial-peers, what syntaxis i need to use in "answer address" command?
i've got problems with calls like 92. - variable length, they matched incoming dial-peer 2, but i need 1
HARIS_HUSSAIN
Try adding $ sign in dial peer 92XX$.
HARIS_HUSSAIN
Thanks a lot. This helps!
