max-conn value causing media-loop error
milind.patel
Hi all CUBE gurus,
Can anyone please help out with below issue.
- We are restricting calls to a specific site using max-conn value assigned to dial-peer on main site CUBE router.
- Dial-peer is matched using incoming called-number for the site.
- Main site CUBE router is running IOS 15.1(4) M4
The issue is we are seeing below media loop error ONLY when that dial-peer runs out of connections (max-conn value is reached).
Can anyone please put some lights on what exactly happens when max-conn value is reached (apart from call being dropped) and why it would cause media loop error?
May 21 07:32:01.497: %CALL_CONTROL-6-MAX_CONNECTIONS: Maximum number of connections reached for dial-peer 1234
May 21 07:32:01.777: %VOIP_RTP-6-MEDIA_LOOP: The packet is seen traversing the system multiple times
May 21 07:32:44.197: %CALL_CONTROL-6-MAX_CONNECTIONS: Maximum number of connections reached for dial-peer 1234
May 21 07:32:44.453: %VOIP_RTP-6-MEDIA_LOOP: The packet is seen traversing the system multiple times
May 21 07:34:20.709: %CALL_CONTROL-6-MAX_CONNECTIONS: Maximum number of connections reached for dial-peer 1234
May 21 07:34:21.013: %VOIP_RTP-6-MEDIA_LOOP: The packet is seen traversing the system multiple times
Thanks in advance
7 Replies 7
Dennis Mink
Without configs, it's guesswork, please include configs of all components involved.
Please remember to rate useful posts, by clicking on the stars below.
Ayodeji Okanlawon
We need to look at your config to see where the loop is happening. Basically when the maximum connection has been reached on a dial-peer, the gateway will try another dial-peer that macthes that destination. Hence it is possible that you have more than one dial-peer to this destination and it is the config on these other dial-peers that is not quite right. Until we see it we wont know
Please rate all useful posts
Thank you both for replying.
Unfortunately, I am unable to put config for the reasons you could imagine. However, I am happy to provide as much info without having to do it.
Aokanlawon
When max-conn is reached and If GW tries to match another dial-peer it will defeat the purpose of max-conn value. I have double checked the config there is no other dial-peer should be matched. However, there is a default hidden dial peer 0. If what you saying is correct, will it match the dial-peer 0?
if you cant post config, can you post the output of
'debug voip ccapi inout'
We have increased the max-conn value under the dial-peer and it is less likely to reach the value at this time.
I am interested in knowing what exactly happens when max-conn value is reached from GW perspective. You mentioned it will try and match another dial-peer. Did you have any document mentioning that ? Also, If i assume what you said is correct then most likely callers did not get disconnected and call went through which defeated the purpose of max-conn value.
For the puprose of redundancy and CAC you can have a scenario where when a certain amount of call is reached on a dial-peer, another dial-peer should be tried..
eg..dial-peer voice 1 voip
      destination-pattern 7777
    max-conn 2
  session target ipv4:10.10.10.10
dial-peer voice 2 pots
preference 1
port 0/0/0:15
In this scenario when when a total of two calls are ongoing, and a 3rd call arrives on that dial-peer you will get the following
The call will then attempt to route via dial-peer 2.
So you can see why this can be very useful. It is not just use for stopping a certain number of calls exiting on a dial-peer, those calls can be routed via another route.
However if you say you dont have any other dp, then thats a different issue. the only way to verify is to look at a debug voip ccapi inout
testeven
Do you see any errors such as:
%SYS-6-STACKLOW: Stack for process IP Input running low
There is a known bug that can cause the router to crash when having excessive loops:
CSCtb77593    router crashes when RTP loop exists in IPIPGW environment
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtb77593
Seems your versions has the fix, but you might want to double check.
Tere.
If you find this post helpful, please rate!
Regards, Tere. If you find this post helpful, please rate! :)
