Max number of Hunt Groups
cairns-a
I have Call Mgr. 4.1(3)sr6.
What is the max number of Hunt Groups for this version?
Trae
Rob Huffman
Hi Trae,
Hunt Pilot Scalability
Cisco recommends using the following guidelines when deploying call coverage using top-down, circular, and longest-idle algorithms:
•The Cisco Unified CallManager cluster supports a maximum of 15,000 hunt list devices.
•The hunt list devices may be a combination of 1500 hunt lists with 10 IP phones in each hunt list, or a combination of 750 hunt lists with 20 IP phones in each hunt list. However, an increase in a number of hunt lists can require increasing the dial plan initialization timer specified in the Cisco CallManager service parameters. Cisco recommends setting the dial plan initialization timer to 600 seconds if 1500 hunt lists are configured.
From this excellent 4.x SRND Guide;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/4x/42dialpl.html#wp1077805
Hope this helps!
Rob
Thanks. That is what I was looking for.
Hi Trae,
You are most welcome!
Cheers,
Rob
