08-02-2016 12:11 PM - edited 03-17-2019 07:43 AM
Hello All,
where can I find out what the maximum number of phones per server that a hardware configuration can support?
Looking at 10.5 on Cisco C210s running ESXi 5.5 4GB of RAM, 1vCPU and 168GB of Provisioned storage. If I am hitting a limit will adding more RAM and another vCPU give me more head room?
All replies rated
08-02-2016 12:21 PM
Please look at this link and see if it helps.
http://docwiki.cisco.com/wiki/Virtualization_for_Cisco_Unified_Communications_Manager_(CUCM)#Version_10.x
08-02-2016 12:45 PM
The options you can use, are limited to what is outlined here:
That vDisk size does not match the specs of a 4 GB and 1 vCPU machine, that's more than twice the size of what it should be.
You can change the OVA specs to match a higher capacity option, but anything that deviates from those 4 basic options, it will be unsupported.
