Maximum call duration timer for a device
united_airline
Beginner
Beginner
Cisco CUCM 9.1
Does anyone knows , is it possible for  the following service parameter in CM (Maximum call duration timer) only apply to a device(s) and not apply to global setting.
I have a need to keep multiple end points which run cameras to be active  and not end the call. Need it to be running  24/7 . IF this is not possible, are there alternative opitons or a 3rd party solution.
JayP
Jaime Valencia
No way to do what you want in CUCM, the parameter affects ALL calls
java
if this helps, please rate
Jaime,
If this is not avaiable. What are my options ?
JP
I don't believe there's any for internal calls, for external calls, most likely TCL scripting.
java
www.cisco.com/go/pdihelpdesk
java
