200
simc92
Beginner
Maximum input received extension mobility - IP Communicator
When I try to type a long email address as UserID in Cisco IP Communicator there is an error message 'Maximum input received'.
We can't create an alias because our users are synchronized with LDAP.
I know there is no more support from Cisco for this product but do u have an idea ?
Thank you.
Best regards.
1 ACCEPTED SOLUTION
Jaime Valencia
Hall of Fame Cisco Employee
There is a limitation for only 32 characters to be allows for user input, there is no way around this, other than using shorter user IDs.
java
if this helps, please rate
5 REPLIES 5
Nithin Eluvathingal
VIP Mentor
Use the USRER-ID  displayed on your CUCM enduser page. Does your USER id showing testtesttest@testtesttest ?
Response Signature
Yes, the UserID is the email address (synchronized with LDAP, I can't modify this field).
You do have the option to use samaccountname as the field for user name in CM instead of email.
Response Signature
Jaime Valencia
java
Thank you!
Create
Recognize Your Peers
Content for Community-Ad
