Maximum No of CSS in CUCM
rohitkupasani
HI,
Sorry if this is asked in some other section of forum, But i couldnt find any pointers which gives understanding of maximum number of CSS in a CUCM deployment.
Cisco docs only says maximum partition in a CSS depends upon partition names etc but nothing related to max CSS>
any help is appreciated.
thanks
Rohit
5 Replies 5
Chris Deren
Correct, there is no hard limit how many CSS you can have, only the limit of partitions within a CSS (driven by number of characters in partition name). From CUCM SRND v.9:
The maximum length of the combined calling search space (device plus line) is 1024 characters,
including separator characters between each partition name. (For example, the string
“partition_1:partition_2:partition_3” contains 35 characters.) Thus, the maximum number of partitions
in a calling search space varies, depending on the length of the partition names. Also, because the calling
search space clause combines the calling search space of the device and that of the line, the maximum
character limit for an individual calling search space is 512 (half of the combined calling search space
clause limit of 1024 characters).
Therefore, when you are creating partitions and calling search spaces, keep the names of partitions short
relative to the number of partitions that you plan to include in a calling search space.
HTH,
Chris
Good approach Chris Deren, plus five for share!!!
Cheers
Bruno Rangel
Please remember to rate helpful responses using the star bellow and identify helpful or correct answers
4 years later i end up here and look who is around.
lol
Glad to see you buddy!!!
Cheers
Bruno Rangel
emiliolara
I know this is an old post but I just wanted to add that if you see the following alert when adding a PT in a CSS
Update failed. TypeDbErrors.CSS_CLAUSE_TOO_LONG
It is because you are exceeding the character limit.
Hoping this helps Google Search when someone searches for that error.
