Maximum ring time on CME 8.1
steven.t27
Beginner
Beginner
Guys
I am having a weird issue here. No matter how to loop my ephone-dns or voice hunt-group or etc. The call will ring out after 1 minute 30 seconds. I do not wish to failover the call to voicemail at the moment. Any ideas?
Router#sh run | s ephone-dn  1
ephone-dn  1  dual-line
number 1501 secondary 62601501
label 1501
description 0862601501
call-forward noan 1502 timeout 300
voice hunt-group 1 sequential
final 1500
list 2000,3000   \\*** all phones has dn 2000 and 3000 to ring them accordinly
timeout 20
pilot 1599
Router#sh ruN | s ephone-dn  100
ephone-dn  100  dual-line
number 1500 secondary 62601500
label MAIN
call-forward all 1599
Router#
6 Replies 6
Mohammed al Baqari
VIP Advisor VIP Advisor
VIP Advisor
I am not sure about the exact requirement, but if you want to forward call to voicemail after hunting, the max hunting time is controlled by "timeout xx" parameter in voice hunt configuration. If all endpoints are SCCP, I prefer to use ephone hunt since it gives more tuning options.
Mohammed
Thanks for the reply, however the call flow that I want to achieve is to loop the call for eternity and not failover to voicemail at all. I want the call to keep ringing until someone answers the call.
ST
If you look under show telephony-servce
Yo will see a section showing vaious tmeouts
show telephony-service
timeout interdigit 4
timeout busy 10
timeout ringing 180
timeout transfer-recall 0
timeout ringin-callerid 8
timeout night-service-bell 12
You can see that this system is at the default 180 seconds for ringing
To change this to say 5 minutes (300 seconds) :-
conf t
telepnony-service
timeout ringing 300
Please note that this will change all ringing to the new setting unless you configure
a different setting elsewhere
E.G on an ephone-dn
number 5001
pickup-group 1
description BOABS NUMBER
name BOAB
call-forward busy 5990
call-forward noan 5990 timeout 15
huntstop channel
BOABS number 5001 will ring for 15 seconds before CFNA to 5990
Also remember that the local PSTN will not ring you externally for ever
the TELCO will have a timer set may be be 3 minutes, you would need to test
to a home phone with no answer for example
Hope this helps
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
acampbell
Thanks for the reply I have also tested out the timeout ringing command under telephony services and tried from various form of source like landline and mobile. All disconnects after 1:30..
Any other ideas?
ST
Hi ST,
What about if you ring the number 1599 internally
What happens then ?
Alex.
Alex
If I ring internally I can ring for more than 1 min 30 second. I have also tried to use different source and carriers to test. SIP Trunks and ISDN BRI still disconnects at 1 min 30 second.
I get this message when I test it on the SIP trunk.
Jun 11 01:19:37.325: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CANCEL sip:62601500@10.100.252.28:5060 SIP/2.0
Via: SIP/2.0/UDP 10.100.1.252:5060;branch=z9hG4bK6A02D1DEE
To: <62601500>
Date: Mon, 11 Jun 2012 02:32:08 GMT
Call-ID: 79E53D15-B2A411E1-8260DC27-ACE9C362@10.100.1.252
CSeq: 101 CANCEL
Max-Forwards: 70
Timestamp: 1339382019
Reason: Q.850;cause=16
Content-Length: 0
Jun 11 01:19:37.333: //47/79E0F765825A/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <62601500>
Date: Mon, 11 Jun 2012 01:19:37 GMT
CSeq: 101 CANCEL
Content-Length: 0
Sent:
SIP/2.0 487 Request Cancelled
To: <62601500>;tag=275D88-69B
Timestamp: 1339381928
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Jun 11 01:19:37.353: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:62601500@10.100.252.28:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Recognize Your Peers
