04-29-2014 09:32 AM - edited 03-16-2019 10:37 PM
Hi All,
According to the link below the router 3945E supported maximum sessions is 2500.
My question is what is the command to see the active sessions on the CUBE, I use show sip-ua calls summary but I'm not sure if it is the same count for the CUBE sessions.
Kind regards!
Solved! Go to Solution.
04-29-2014 10:02 AM
Please refer this URL
https://supportforums.cisco.com/document/123281/how-check-active-call-count-sip
//Suresh
Please rate all the useful posts
04-29-2014 10:02 AM
//Suresh
04-29-2014 10:42 AM
Thanks a lot Suresh!
So there is only an approximate of the sessions. No specific command available for the active sessions.
