MCS 7816-I4 with CUCM 7.1.3b booting issue
Bhavani Sankar
Hi ,
I am facing problem with CUCM 7.1.3 , as it is not booting and throwing the below mentioned error message. I am attaching the error snap shot also.This model server is having only one HDD of 250 GB capacity.
Error Message-- "ext3-fs error (device/sd 6) in start-transaction journal has abborted".
Please let me know it there is any solution for this issue.
Thanks in advance.
Sankar.
Similar issue is handled already on this thread https://supportforums.cisco.com/thread/2083723 .
Always, do a casual search on this forum for the issues faced. Saves time.
GP.
10 Replies 10
Gajanan Pande
Did you complete the manual file system check ( using recovery disk ) as shown in the snapshot ?
GP.
No. Can you share me the procedure.
If you observe the screenshot carefully, the procedure is very much provided in it. Reboot the system & follow the steps prompted to complete Manual File System Check ( FSCK ). Keep the recovery disk handy with you & insert in the driver whenever prompted & continue with next pr0mpted steps.
Refer the OS admin guide for your CUCM version available on CCO for any such activities.http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_maintenance_guides_list.html
If it appears difficult to perform, feel free to raise a TAC case with Cisco.
Pls rate the post if it helps.
GP.
IS the recovery disk and CUCM installation disk same?
No you need to download the Recovery software for your CUCM from CCO, here it is http://www.cisco.com/cisco/software/type.html?mdfid=282421166&catid=278875240&i=rp
Also refer the document http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080b1f305.shtml
GP.
GP.
Hi GP,
Thanks a ton. I resolved it by recovery DVD, which came from cisco.
Sankar.
NP Sankar, Glad I could assist.
Thanks for the nice ratings.
Cheers !!
GP.
Hi Gajanan,
We have MCS 7816-I4 with CUCM 7.1.3b and got the same issue. Pl find the attached photo.
The link provided above is no longer working. Great if you can helpIMG_2341.JPG
If you mean the link for the recovery disk, right now your only chance would be your SE.
java
if this helps, please rate
